December 31, 2025, 03:18:29 AM *
Pages: 1 [2]   Go Down
Author Topic: I Keep melting my boot on my Exhaust! Any Suggestions?  (Read 15293 times)
blackvalkyrie
California
« Reply #40 on: June 18, 2014, 05:40:08 PM »
I too have exactly the same problem and I'm a size 13....i ended up replacing the heat shield...now I'm very very careful when i put the kickstand down, but on occasion I still get boot melt..so I use mother's to clean it off as soon as the pipe cools down...it's a design problem w/ the kickstand..I'm thinking about extending the kickstand bar out a bit...I also did think about putting a piece over it like you did...it's frustrating! Angry
I did some research to see if I could find some chrome exhaust shield that I could clamp on.  I could not find anything that looked like it would work.  I am about to the point of getting black exhaust wrap and metal zip ties and wrapping 6 to 8 inches of pipe on both sides were my boots could contact.  Has anyone had this problem and if so how did you remedy the issue.
blackvalkyrie
California
« Reply #41 on: June 18, 2014, 05:44:02 PM »
I try to keep my foot further up the peg..towards the front of the bike cooldude
Well after I noticed I had melted my boot the first time I have made a conchies effort to keep my boots clear of the pipes but when I am just enjoying the ride I find my heals naturally make it back to the pipes.  So since it seams this will continue to be issue for me any thoughts on about a shield or wrap idea? ???
« Reply #42 on: June 18, 2014, 05:51:17 PM »
Quit buying those rubberized boots.
Get REAL leather ones.
Actually, you need to spread your legs farther apart when ya get ready to get off.
This is a real problem for anyone who has never ridden this big of a wide engine bike.   I had ridden a BMW Boxer for awhile before I got my Harley and then the Valkyrie.    The Boxer with the jugs sticking way out to the side, I got used to not touching the cylinders.    Really, it is just a matter of what ya get used to.
nogrey
Nampa, Idaho
« Reply #43 on: June 18, 2014, 05:55:53 PM »
Maybe a better pair of boots. I have never melted my boot on the exhaust, dont know if I have ever touched it or not. Maybe my boots are heat resistant and keeps them from melting? I usually wear my red wings when I ride.
I was thinking the same thing. I seem to always get a little boot on my (absolutely stock) exhaust pipes during a ride. But different boots make a difference. I am wearing Bates composite toed side zip boots and they seem to have a little higher melting point......I guess.
blackvalkyrie
California
« Reply #44 on: June 18, 2014, 06:05:16 PM »
gonna check em out. thanks cooldude
quexpress
Montreal, Québec, Canada
« Reply #45 on: June 18, 2014, 06:38:23 PM »
I do it all the time when putting the kickstand down not as much as I used too I learned it sucks to clean off. 0000 steel wool and some effort takes it off.
Oven cleaner (Easy Off) makes it easy to remove these marks. Put some on a rag, spread on boot mark and wait a few minutes. Wipe off and clean with water. Done!
I still have a full deck.
I just shuffle slower ...
blackvalkyrie
California
« Reply #46 on: June 18, 2014, 10:09:49 PM »
good to know! thanks Smiley
Mapper
Montclair, VA
« Reply #47 on: June 18, 2014, 11:00:54 PM »
Softer soles melt easier when putting the kickstand down if you aren't careful.
Comes off okay with fine steel wool, as someone else mentioned.
nswiley
« Reply #48 on: June 19, 2014, 03:38:16 AM »
Try Goo-Off it will take the black off your pipes.
« Reply #49 on: June 19, 2014, 06:50:13 AM »
My wife got her boots on the exhaust every once in awhile.
Used good old Easy Off.    Worked like a champ.
Put the Vikings on and that ended the boot marks for some strange reason.
Farther
Quimper Peninsula, WA
« Reply #50 on: June 19, 2014, 07:02:13 AM »
I stopped looking down there and now I don't have a problem.
~Farther
« Reply #51 on: June 19, 2014, 11:36:38 AM »
Go barefoot, it won't take ya long to learn to keep your feet off the pipe.
LOLOL  I was going to respond with that comment, but I thought it might seem harsh........thanks RJ....too funny
DVG52
« Reply #52 on: February 03, 2020, 12:45:11 PM »
I do the same thing from time to time, Until you find a solution , Just heat the exhaust up spray it with oven cleaner and wipe it off, It comes off easy and no damage to pipes.
rug_burn
Brea, CA
« Reply #53 on: February 04, 2020, 09:12:44 AM »
Looks like that exhaust is running hot;  this happened to me when my carbs were clogged up and  running lean.    I used chrome polish to get the marks off, and finally got the mixture to where it belonged...
I actually rest my heel on that shield plate on long rides, just the right position for my bad ankle.
...insert hip saying here..
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #54 on: February 07, 2020, 01:49:58 PM »
wear Ice Skates 2funny
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
Pages: 1 [2]   Go Up
