February 08, 2026, 08:31:54 AM
Help with front wheel MFG numbers
Topic: Help with front wheel MFG numbers (Read 737 times)
John U.
Southern Delaware
March 02, 2014, 08:13:49 AM »
I can't seem to locate a working parts fische that will give me stock numbers for Valk front wheels.
I know the 97s use a different bearing but aren't wheels for rest of the years and models interchangeable? Please correct me if I've got that wrong, don't want to make a costly mistake.
Anyone know the number cast into the wheels that fit a 97?
Thanks in advance.
BTW, what happened to HDL's parts fische, I can't seem to find it.
Last Edit: March 02, 2014, 08:34:26 AM by John U.
olddog1946
Moses Lake, Wa
Re: Help with front wheel MFG numbers
March 02, 2014, 09:02:30 AM »
44650-MZ0-674 is the current # listed for a 97 GL1500CT old # was 44650-MZ0-670...
The old hdlparts.com apparently has been upgraded like windows 8 was from 7.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Moses Lake, Wa. 509-760-6382 if you need help
Disco
Republic of Texas
March 02, 2014, 05:04:33 PM »
I can't comment on the original part numbers, but the front wheels are all interchangeable because the axles are the same 20mm diameter.
The difference between the 97 front wheels and the other years is the bearing OD. The 97 uses 6004 bearings (42mm OD) and the rest use 6204 bearings (47mm OD).
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
VRCC 27,916 IBA 44,783
