February 08, 2026, 08:31:54 AM
Need some help
Topic: Need some help (Read 1197 times)
TJ
Lake Placid , Fl.
Need some help
March 06, 2014, 11:53:03 AM »
I need the part # or where to find it...
It's the little brass bushings that go in the fairing on an I/S that the screws that hold the speaker panel on goes into... There are 4 on each side....
Bugslayer
Lubbock, Texas
Re: Need some help
March 06, 2014, 12:35:18 PM »
Do you see it here?
http://www.partsfish.com/oemparts/a/hon/506c2fb6f870023420a31c60/meter-panel
TJ
Lake Placid , Fl.
Re: Need some help
March 06, 2014, 12:43:02 PM »
No... It should be # 13 but that's a nut with a flange on it... That's what I got when I ordered
it.... Have been on HDL , Partszilla ,Ron Akers and and that site...
Re: Need some help
March 06, 2014, 02:44:11 PM »
I reused my old ones. When they came out of the fairing I put them back in with a 2 part epoxy glue system. AND I put anti seize on the threads on the reinstall. I was VERY CAREFUL to NOT get the epoxy in the threads. RIDE SAFE.
trout dude
Hammond Louisiana
Re: Need some help
March 06, 2014, 02:45:22 PM »
TJ
You can pull them out and put them back with super glue or jb weld. The super glue worked great for me and had the screws out several time with out any problems. Hope this helps.
Dennis
Re: Need some help
March 06, 2014, 02:49:20 PM »
Quote from: trout dude on March 06, 2014, 02:45:22 PM
TJ
Dennis
Thanks Dennis from Dennis!!
Been meaning to do THAT fer awhile.
RIDE SAFE.
TJ
Lake Placid , Fl.
Re: Need some help
Reply #6 on:
March 06, 2014, 03:05:20 PM »
I had 2 of them fall into the dark reaches of valk haven , so I need new ones.... These have never been glued it before so I'll be super gluing them in....
Re: Need some help
Reply #7 on:
March 06, 2014, 03:33:29 PM »
In the dim recesses that I pass off for my mind someone posted about the replacement ferrules that are needed. Try the search function on the tech board and the general board. At this point in time that is the best I can do for you. When you glue them back into the fairing DO NOT be in a hurry putting the bolts/screws back in until the adhesive of your choice is COMPLETELY setup/cured. RIDE SAFE.
Re: Need some help
Reply #8 on:
March 06, 2014, 06:27:31 PM »
The part number is on JeffK's generic parts page linked to in ShopTalk.
http://www.jkozloski.com/generic_parts.htm
Almost to the bottom of the page on the left side.
90316-MJ1-000 is the part number you are looking for.
Hay
Re: Need some help
Reply #9 on:
March 06, 2014, 07:16:01 PM »
Quote from: HayHauler on March 06, 2014, 06:27:31 PM
Hay
Yer a good guy there Jimmyt!
RIDE SAFE.
TJ
Lake Placid , Fl.
Re: Need some help
Reply #10 on:
March 06, 2014, 07:32:29 PM »
Thank You.....
