February 08, 2026, 08:31:27 AM
Flush gas tank.
Topic: Flush gas tank. (Read 1051 times)
PhredValk
Edmonton, Alberta, Canada
Flush gas tank.
March 07, 2014, 10:43:28 PM »
Hey. I will be removing my gas tank this weekend. I want to keep it in the basement to do some petcock modification, and don't want to smell up the house with gasoline fumes. After emptying it what should I flush it with? Water could be bad, so I'm thinking rubbing alcohol...
Suggestions?
Fred.
Last Edit: March 07, 2014, 10:46:06 PM by PhredValk
VRCCDS0237
Re: Flush gas tank.
March 08, 2014, 09:33:34 AM »
I would not suggest to flush it with anything.
Empty the tank as best possible
turn it upside down with the fill hole at the lowest point
and let it sit in the sun for a few hours.
John U.
Southern Delaware
Re: Flush gas tank.
March 08, 2014, 04:19:52 PM »
Phred, have you tried to look around in there to see if there are problems such as rust? An inspection mirror will let you get a better look. If no rust or sediment problems, I agree with just let it dry.
PhredValk
Re: Flush gas tank.
March 08, 2014, 04:46:33 PM »
It should be warm enough tomorrow, I'll give it a try. Thanx.
Fred.
VRCCDS0237
Re: Flush gas tank.
March 08, 2014, 07:18:54 PM »
It depends on how long you want to let it sit around smelling.
I used engine fogging spray for the IS tank when I shipped it. To prohibit rust and cover/remove the smell of gasoline for shipping.
Michvalk
Remus, Mi
Re: Flush gas tank.
March 08, 2014, 07:53:32 PM »
You can take a hose from the tailpipe of your car running and stick it into the tank. It will dry the tank, and the fumes will get rid of the gas fumes. I don't know the science, but, it works for the guys welding on the tanks
valkyriemc
NE Florida
Re: Flush gas tank.
Reply #6 on:
March 10, 2014, 07:33:00 PM »
Flush tank out on nice white (wife's) towel, and you will see any red-ish stains or tiny rust particles, and give you a hint of what's going on in the tank.
Veteran USN '70-'76
Re: Flush gas tank.
Reply #7 on:
March 11, 2014, 07:19:56 AM »
There's vent passages in there. There's not a right way to turn it
(that I found) where all the gas comes out.
