February 08, 2026, 08:31:52 AM
Does anyone make................
Topic: Does anyone make................ (Read 926 times)
spongebob
Alabama
March 08, 2014, 07:09:19 PM »
a thinner head gasket for the Valk?..... I have had mine Dyno'ed 3 times since I bought it new in 03....... Best it would do is 85Hp.. I have changed gaskets on my racing dirt bikes for years. That makes a noticeable difference.......Thanks....
Valker
Wahoo!!!!
Texas Panhandle
Re: Does anyone make................
March 08, 2014, 07:13:07 PM »
Running stock exhaust? That number is about right with most aftermarket pipes.
March 08, 2014, 07:38:49 PM »
Do you have a California bike? Look for a charcoal canister under the swingarm. If so, that's all you'll get. The CA bikes have milder cams and different carbs for better emissions.
Big Mike
I can not remember my last bad day
Taylor MI
March 09, 2014, 06:11:28 AM »
Cometic in Ohio has copper head gaskets in varying thicknesses for the 1500 engine.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
March 09, 2014, 08:43:56 AM »
Only 85hp? Sumting Wong! Mine pumped out in the mid-90's on a day when the heat was pushing 100 with matching humidity. Not the best conditions for a dyno run. Plenty of simple stuff can be done, including aftermarket pipes which can add some oomph when used in concert with other changes.
