February 08, 2026, 08:32:47 AM *
Author Topic: Side panel center piece?  (Read 1084 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: March 09, 2014, 08:39:58 AM »
Has anybody changed one out and what is involved?
« Reply #1 on: March 09, 2014, 08:48:46 AM »
No, but from what I've read, a lot of swearing and tool throwing is involved (similar to the Ujoint boot).
Sorry.
I would search How to Remove Center Cover?  I recall reading a thread or two with very good advice.
Joe Hummer
Arnold, MO
« Reply #2 on: March 09, 2014, 01:21:09 PM »
Hey Robin,
It isn't that difficult but does take some swearing.
While you don't have to remove the tank, it make the process a little easier because it gives you more angles to get at things.  It will also get the petcock handle out of the way giving you more room to move around.
You will also want to protect the center cover from the motor/alternator or you could end up with scrapes.  Painters Masking Tape works pretty good for this.  Just apply it down low enough to cover the motor parts.  Otherwise, you can put a rag over the motor.
Work from the left side of the bike for the most part.  You will have more access to everything.
Steps are as followed.
1) Remove the two screws into the frame (under the side covers).  Do not lose the little bushing washer that is under the cover.  These keep you from over tightening the screws and busting the cover.
2) Wiggle the cover up until it pops out of the holder at the bottom.  This may take a little effort and time...and usually where the cussing comes into play.
3) Remove the seat lock from the cover.  You will need to slide out the spring clip, undo the cable, and slide the lock out of the cover.  You could leave the lock in place on the cover but you have to get the cable off and I think it is easier to do this with the lock free.
4) Remove the bank senor.  Pay close attention to how this is mounted.  Get it upside down and your bike won't start.  I usually pull the cover out a little and can get a screwdriver on one screw.  Then rotate the sensor to give enough room to get the other screw.  I don't think you can get to the connector to undo it...but if you can...that is the preferred method.
5) Pull the cover out.
Installation is the reverse of the above.
Hope this helps.
Joe
1999 Valkyrie Interstate
Momz
ABATE, AMA, & MRF rep.
« Reply #3 on: March 09, 2014, 01:46:13 PM »
Obviously the right and left side covers are removed first.
Then you must remove the seat/key mechanism (not that difficult), two screws that hold on the "Tip Over Sensor", and then carefully pull up on the center section.
It helps if you remove the battery first, but if your removing it from an I/S it is a bitch because there is far less room due to the radio and associated wires/cables.
Be careful not to accidently "kink" the seat locking cable.
A two beer job on an I/S and a one beer job a Standard or Tourer.
ALWAYS QUESTION AUTHORITY!
« Reply #4 on: March 09, 2014, 05:02:43 PM »
When I bought my interstate it can with chrome side covers with a black center cover installed, but the PO also included a Chrome center cover (not installed) and I see why that was when I change it.  It is worse than changing the alternator and installing the U-joint boot combined!
« Reply #5 on: March 09, 2014, 05:12:54 PM »
It's a royal pita.  The grommet at the at the bottom that it goes into is what gave me the most grief.  It goes in there just so....and comes out the same way.
Plenty of painters tape and place a bunch of shop rags down there to prevent scrapes and damage.
