January 29, 2026, 05:30:44 AM *
Author Topic: The D Screw Carburetor Help  (Read 2684 times)
woefman
Arizona
« on: July 28, 2009, 07:45:12 AM »
Hello ,
Reading through the Book I see some talk about the D screw tool
anyone have pictures of the screw, it's location and the tool ( i know some use an antenna ).
mine seems to have 6 reg (flat blade) screws for adjusting mixture.
does this mean someone changed mine out ?
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
« Reply #1 on: July 28, 2009, 08:04:30 AM »
Hello ,
Maybe someone did change yours out... I think Dag said European Valks don't have the D heads...
D head:
http://www.motionpro.com/motorcycle/partno/08-0242
I don't see the green thumb ratchet over at harbor freight anymore:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94011
dreamaker
Harrison Township, Michigan
« Reply #2 on: July 28, 2009, 08:35:37 AM »
D-Bit and Harborfreight 1/4" thumb holder.
Dan
Udo
Germany, Krefeld
« Reply #3 on: July 28, 2009, 08:39:17 AM »
My German Version doesn´t have the D screws
« Reply #4 on: July 28, 2009, 10:28:55 AM »
I'm wondering which screws you're looking at.. There are 6 regular screws for the carburetor drains[horizontal] which can be readily seen on the bottom side of the carbs.. There are also 5 screws[also horizontal] under the choke linkage covers which are for slide position adjustment..The pilots are contained in a vertical casting in the fuel bowl housings and are not readily 'seeable'..Now if some one has removed them and cut/slotted them, then maybe that is what you are seeing..
« Reply #5 on: July 28, 2009, 10:44:20 AM »
I live in Mesa. Maybe we can meet and I'll help you.
Kingbee
VRCC# 576
Northern Illinois
« Reply #6 on: July 28, 2009, 11:33:20 AM »
Adjustment screw at the UNDERSIDE of the carb.
1999 Interstate
2000 Interstate
2004 Rune
woefman
Arizona
« Reply #7 on: July 28, 2009, 12:02:44 PM »
West Side
Avondale/Goodyear Area
and
woefman
Arizona
« Reply #8 on: July 28, 2009, 12:09:11 PM »
When I Look @ my bike ( carbs on bike)  I see the screws in plain sight.
Maybe I need to dissect this bike more.
The Manual seems worthless at least until have bike apart.
I was just trying to learn this Carb stuff on this bike for when the time comes.
I also wanted to learn the resync.
 3 of my friends have the gauges to resync
but I don't trust they know what they are doing, based on questions I have asked them.
and
woefman
Arizona
« Reply #9 on: July 28, 2009, 12:15:27 PM »
Hello ,
D head:
Thanks To all and GReat Fast Replies thank you all
« Last Edit: July 28, 2009, 12:17:49 PM by woefman » Logged
and
Dan Manko
« Reply #10 on: July 28, 2009, 12:41:06 PM »
The "D" screws are under the carbs,tucked in tight and up high behind the black intake tubes. Use a mirror to see them.
« Reply #11 on: July 28, 2009, 02:12:30 PM »
the screws you see 'in plain sight' shouldn't be the pilots.. To see these you need to either stand on your head, flop the bike upside-down or use a mirror.. The 'D' on the screw head may be difficult to see even while you're looking right at it[ with carburetors still on the bike of course].. These are the screws as I stated earlier that go straight up vertically in the carburetor..
woefman
Arizona
« Reply #12 on: July 28, 2009, 11:15:04 PM »
Thanks ....my goof up I must have been looking at the drains.
and
