February 08, 2026, 08:32:44 AM *
Author Topic: trip odometer button  (Read 828 times)
hogjol55
Ocala, fl
« on: March 10, 2014, 02:57:52 PM »
My trip odometer button on my 99 IS is stuck in the trip 1 spot.  Any suggestions?  Thanks  JD in Ocala
JD in Ocala
« Reply #1 on: March 10, 2014, 05:36:24 PM »
    Little spray cleaner(contact cleaner)because mine pushes easy between the main odo and the 2 trip odo's. Just for yuks and giggles did you try pushing it fairly hard?? When you figure out what made it work again PLEASE post back here.  cooldude RIDE SAFE.
« Reply #2 on: March 11, 2014, 09:56:56 AM »
You could try disconnecting the battery for a bit.
hogjol55
Ocala, fl
« Reply #3 on: March 11, 2014, 03:02:37 PM »
I sprayed the button every so often for 24 hrs. with electronic spray.  No luck.  Sprayed it with PB blaster.  15 min. worked like new.  Who new.  Good to know.   JD in Ocala
JD in Ocala
« Reply #4 on: March 12, 2014, 08:20:52 AM »
Well, that's a cover there, to protect the switch.
If you've had success with spraying it,
I would say the cover has lost it's integrity and
it's ability to protect the switch.
Which would mean there's more problems
for you, in the future, regarding the switch.
