November 25, 2025, 11:32:01 PM *
Author Topic: Synthetic and a wet clutch  (Read 2059 times)
G-Man
White Plains, NY
« on: March 13, 2014, 11:38:28 AM »
Just read that synthetic oil should not be used with a wet clutch as it may cause slipping.  Is this true?
Hope I'm not opening up a can or oily worms.
big poppa pump
San Antonio, TX
« Reply #1 on: March 13, 2014, 12:00:03 PM »
Bull! I have been using Shell Rotella T6 full synthetic for a long time now and my clutch is yet to slip.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
pocobubba
Pocomoke , Md
« Reply #2 on: March 13, 2014, 12:01:40 PM »
There are a lot of Motorcycle specific Synthetic oils on the market that specify wet clutch compatible . Lots of guys have been using Mobile One for years , also Rotella Syn. Honda sells there own Synthetic , I believe you have been misinformed  .
« Reply #3 on: March 13, 2014, 12:31:36 PM »
It does not require motorcycle specific synthetic oil...... any synthetic of the proper weight will do.... so long as it does not have the infamous FRICTION MODIFIERS, OR ENERGY CONSERVING words on it.  If you do that, you will be fine, if you make a mistake, you can burn your clutch in short order.
I've been running the T6 Rotella for years in both bikes.  It's all good.  Not as quiet as Amzoil, not as expensive as Amzoil either (by a long shot).
« Last Edit: March 13, 2014, 02:49:16 PM by Jess from VA » Logged
G-Man
White Plains, NY
« Reply #4 on: March 13, 2014, 12:46:37 PM »
Thank you.
I've been using synthetic Rotella for years now in the Valkyrie.  But now I also have the 1100 shadow and was looking on the net for oil volumeand came across an "article" that gives all the particulars for the bike and it's oil change, and it specifically said not to use synthetic with a wet clutch.
Thanks for seeting me straight.
« Reply #5 on: March 13, 2014, 01:05:48 PM »
only if a bike has an under sized clutch vs the amount of HP and TQ the engine makes. the org Suzuki Bandit 1200 had the problem. couldn't use syn, some would burn the clutch up. Traded mine in for the Valkyrie.
There are also syn oils that are rated for wet clutchs, some of the specs are AO-1, CA-2 etc and then there are no problems.
saddlesore
« Reply #6 on: March 13, 2014, 06:05:19 PM »
On a thread earlier this week I asked about additives and the wise men here told me not to use any.
My experience with synthetic oil has been positive but I change the oil and filter at around 6500 miles.
If I run it per specs (8000miles)  there seem to be something wrong. Maybe an occasional slip in the clutch.  It's usually in hot weather.  I don't want to take any chances so I change it.
DARE TO BE DIFFERENT
« Reply #7 on: March 13, 2014, 06:39:59 PM »
Thank you.
Owned the VT1100T (Shadow Tourer), and when I went to Amsoil synthetic oil, not only did I not have any problems with the clutch, but I also got 7% better fuel economy.
This meant that I saved the higher cost of the synthetic oil by paying less for gas. Then there is the annual oil change, instead of 2-3 times a year.
snakemeister
Alabama
« Reply #8 on: March 13, 2014, 07:53:16 PM »
  My '97 Tourer has 100,000 on it and has nothing but Mobil I 15-50 run in it. The ONLY repair to the drivetrain as been to have the rear drive rebuilt at 85,000.
« Reply #9 on: March 14, 2014, 06:07:27 AM »
more proof that moly in the oil does no harm to a motorcycle engine.
Mr.BubblesVRCCDS0008
« Reply #10 on: March 14, 2014, 07:41:16 AM »
I've  ran mobil 1  15W 50 for over 172,000 miles in my interstate. I did have to put a clutch in at 160,000 but it was rivet failure not slippage that killed the clutch.
RicCA
California Bay Area
« Reply #11 on: March 15, 2014, 09:37:05 PM »
Im a bit confused about these oils..... I have looked at a few of them listed and they say diesel synthetic oil.... like the shell Rotella T6 and the Mobile 1 1300..... So are you using the diesel oil or am I looking at the wrong oils??? Help Please
Ric
« Reply #12 on: March 16, 2014, 06:24:24 AM »
Ric
yes diesel. A diesel engine stresses the oil more than any watercooled m/c engine ever could.
