September 11, 2025, 02:09:38 AM *
Author Topic: mp3 player for interstate.  (Read 1186 times)
oldfella
« on: March 18, 2014, 09:10:03 PM »
I would like to install a mp3 player with usb stick to my interstate. Does anyone know where I can get one that is set up to plug into the valkyrie electrics. I already have one on my GL1800 instead of the CD player. If anyone can help it will be most appreciated.
Shelly
Nottingham, MD
« Reply #1 on: March 19, 2014, 06:23:39 AM »
all I did was  hook my apple ipod/mp3 player to the aux jack with a 6 foot jack extension I bought from target for a couple of bucks. the connection is behind the right side cover if I remember correctly.
« Reply #2 on: March 19, 2014, 06:26:15 AM »
I did the same thing Shelly and I have a magnetic tank pouch for it that sits on the tank.
Joe Hummer
Arnold, MO
« Reply #3 on: March 19, 2014, 07:12:08 AM »
Chances are...you will not find a module that will allow you to directly connect your MP3 player to the Valkyrie radio so that you can control your MP3 player from the radio controls.   Sad  I have looked pretty hard for one and came up empty and since these bikes are not in current production, you won't get anyone to make one.  You only option is to go with what the other have recommended...plug into your Aux cord with a 1/8" male to male cord and place the MP3 player where you can get to it.
1999 Valkyrie Interstate
« Reply #4 on: March 19, 2014, 07:20:50 AM »
Yea, what Joe says...  But, you can put the radio on AUX and control the volume of the MP3 and if you have a CB, the MP3 will be muted when the CB is receiving a signal.  Smiley
Hay  Cool
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: March 19, 2014, 08:09:00 PM »
You could also build an aux fuse panel under the seat and run power to your Ipod or other devices, like GPS, cruise control, cig lighter. Run it from the battery with a fused line on a relay triggered bu the aux wire in the right side panel so it's only hot with the key on.
Fred.
VRCCDS0237
flsix
« Reply #6 on: March 20, 2014, 02:59:04 PM »
This is all good info. cooldude
Glad you asked the question oldfella.
2013 F6B
           ESCHEW OBFUSCATION
« Reply #7 on: March 21, 2014, 07:54:45 AM »
I found the mp3 player I was using did not have enough power to fully energize the radio aux output.
I had to have the mp3 player at full volume, and the radio also full up volume.
Just was not what I had wanted nor expected.
« Reply #8 on: March 21, 2014, 08:01:08 AM »
The IPhone works fine.
« Reply #9 on: March 21, 2014, 08:57:58 AM »
Welcome oldfella! I see this is your first post.  Smiley  I pipe my tunes from the iPod to the speakers in my helmet. I ride Stanards and put all my communications through a J&M Integrator.
My rides:
Six-Cylinder Hooligan
« Reply #10 on: March 23, 2014, 08:05:52 AM »
You could always try one of these- http://www.amazon.com/ThinkGeek-T613-BNC-Boostaroo-Portable-Amplifier/dp/B000219896
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #11 on: March 23, 2014, 05:26:14 PM »
Salty, What are those helmet speakers you speak of? Are they wired or wireless?
« Reply #12 on: March 23, 2014, 06:24:39 PM »
They are wired. See that coiled lead going over to the helmet on the right?
http://www.jmcorp.com/SeeProducts.asp?PF=12
My rides:
dragon_slayer_129
Throttle Jockey
Leipsic, OH
« Reply #13 on: March 24, 2014, 05:12:48 PM »
I use either a standard mp3 player (sansa clip) or my old trusty gps mounted in a RAM mount.  I have a garmin nuvi 680 that has a sd card slot on it that you can load up with mp3's and play through the aux jack with a 6' cord and get directions as well all in one unit.
The nuvi 680:
http://www.amazon.com/Garmin-4-3-Inch-Bluetooth-Portable-Navigator/dp/B000MF4N42/ref=sr_1_1?ie=UTF8&qid=1395706332&sr=8-1&keywords=garmin+nuvi+680
Sansa clip:
http://www.amazon.com/SanDisk-Sansa-Clip-Player-Black/dp/B002MAPT7U/ref=sr_1_2?ie=UTF8&qid=1395706111&sr=8-2&keywords=sansa+clip
Dragon Slayer 129
'01 Interstate - Fast Black w/loads of chrome - 63K miles
'95 CBR 600F3 - 67K miles
'14 Bennington GSR2250 Tri-toon 150HP Yamaha
To many toys not enough time to play !
[img width=347 height=175]http://i371.photobucket.com/albums/oo160/Rashed_F3/vtx%20forums/VisitedStatesMap.jpg[/img
