September 11, 2025, 02:09:32 AM *
Author Topic: Brake light does not brighten with hand lever  (Read 1039 times)
Biker Bill
« on: March 19, 2014, 07:30:47 PM »
Checked my lights today and found that my brake light brightens when pressing the foot brake lever but does NOT brighten when operating the hand brake lever.  Any ideas about what could be wrong and how to fix it?
Joe Hummer
Arnold, MO
« Reply #1 on: March 19, 2014, 07:54:22 PM »
Sounds like a dirty switch.  It is located under the brake lever and reservoir.  take it off the bike, clean with contact cleaner, throw some WD40 at it, put it back on...and give it a test.
1999 Valkyrie Interstate
« Reply #2 on: March 19, 2014, 07:56:39 PM »
You should hear a distinct "Click" when you pull in the lever.  It's the switch activating.  #1 on this page
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500C+A/FR.+BRAKE+MASTER+CYL./parts.html
Check to make sure the lever is activating the switch.  Check the wiring.
Mr.BubblesVRCCDS0008
« Reply #3 on: March 19, 2014, 08:22:27 PM »
I cleaned my several times before I finally decided to get a new one. Cheap and easy to replace. I got worried about someone rearending me.
« Reply #4 on: March 19, 2014, 08:58:18 PM »
Contact cleaner yes, WD40 no. It might simply be the connectors at the switch.
Biker Bill
« Reply #5 on: March 20, 2014, 06:11:07 PM »
Okay, I need to remove the switch and clean it.  I can hear the "click" when I pull the handle.  So it is activating but apparently not making contact.
Any tips on removing the switch?  Any parts spring activated that will pop out and disappear in the lawn?
Joe Hummer
Arnold, MO
« Reply #6 on: March 20, 2014, 06:14:43 PM »
the switch is held on with a single phillips screw.  No springy parts unless you fully disassemble the switch.
Joe
Biker Bill
« Reply #7 on: March 20, 2014, 06:17:23 PM »
Good!  Thanks Joe, appreciate the info.
Bill
Chiefy
Sarasota, Florida
« Reply #8 on: March 20, 2014, 08:04:09 PM »
Look up in there and be sure the connectors are seated before you begin surgery.
Biker Bill
« Reply #9 on: March 21, 2014, 01:29:13 PM »
Okay.  I cleaned the contacts; reinstalled the switch...brake light still does not brighten when switch activated. Hmm.  Checked connections for tightness...okay there.  Still would not brighten.  Next I put a jumper wire between the wire connectors, eliminating the switch...the light brightens!  Ordered a new switch from Partzilla as Joe suggested.
PhredValk
Edmonton, Alberta, Canada
« Reply #10 on: March 21, 2014, 10:14:45 PM »
There are no Phillips screws on the Valkyrie (or any Goldwing, for that matter). They are JIS screws, and if you don't want to strip them with a Phillips driver you should find and order a set of JIS drivers. I used to strip screws all the time, but with my JIS drivers I haven't stripped a screw.
Fred.
VRCCDS0237
« Reply #11 on: March 21, 2014, 10:22:34 PM »
Phred good tips I didn't know that but do now  uglystupid2 and I will get a set cooldude
Biker Bill
« Reply #12 on: March 23, 2014, 06:38:38 PM »
I have the JIS drivers and there is a difference from phillips.
While waiting for my replacement switch I opened up the old switch, cleaned the points with and emory board; sprayed it thoroughly with contact cleaner, and it worked!
Mounted it on the handle bar and went for a ride Cheesy
Still plan on installing the new one when it arrives as it will be more weather/dirt resistant than the one I had to pop open.
