September 11, 2025, 02:04:58 AM *
Author Topic: Installing steering stem bearings  (Read 1252 times)
Firefighter
Harlingen, Texas
« on: March 20, 2014, 05:23:24 PM »
Finally decided to install new steering bearings. The 2000 IS would wobble around at speeds under 30. I was suspicious of the bearings for awhile. I have attempted to adjust the bearings a couple of times. When I got the wheel and faring off, down to the bracket that holds the forks, I was shocked, moving this fork bracket back and forth, the bracket would hang in the straight forward position. Could not feel this with the weight of wheel, fender, forks, etc. Felt like a spring and ball detent. The bottom race did have bearing marks, but not as bad as I expected. I have read and researched for a while how to do this job, quite a bit of time (for me) as its my first time. I was cussing when I was trying to adjust by the book, what a pain to do. Torqued to 9 pounds and put forks, wheel, brakes, fender,etc back together as my Clymer instructed. Had to research as my Clymer had the pinch bolt torque wrong,   ( don,t know what I did when I replace the front tire twice already) Used a scale to check for the 2 pound pull to turn the steering, and mine came out to 7 pounds! Ahh! Anyway I put the handlebars back on and plugged in enough wires to start the engine. Rode the bike, without faring and a bunch of stuff tied out of the way. Seems to be fixed, rode fast and slow, no speedo, so not sure how fast, but I think my problems went away.  Hope I don't have to take apart to readjust to soon. Now I have to repair some of the plastic screw holes in the faring and chrome windshield accent, (ones with the brass thread insert) and route a lot of wiring, as I have stuffed a lot of neat things under the fairing. Hope to be riding again soon. Firefighter
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
jimmytee
Elizabethtown,KY
« Reply #1 on: March 20, 2014, 08:04:53 PM »
I just replaced my steering bearings as well. I have the Clymer book. When I adjusted my adjusting nut to the rated torque and did the scale  test( this is without the forks back in) I was at 4-5 lbs.  Did you pull it apart and re torque?  Have not yet rode mine, I also rebuilt my forks with progressive springs and I'm going to replace my wheel bearings up front too. Been out of town since Monday and just got back, plus I am polishing all the aluminum to a mirror shine, so am not done yet. Got my trees done and one fork. Going to polish the other one tomorrow.
« Reply #2 on: March 21, 2014, 07:43:11 AM »
I adjust them with a good spring scale, but, with the forks/wheel on.
They should be adjusted so s the spring scale shows 1.75- 2.25# to just start the forks turning and then gravity usually takes over.
Too loose which is what most folks end up experiencing is the looseness/slop and bearing indexing.
Too tight and the bike will hunt.
Firefighter
Harlingen, Texas
« Reply #3 on: March 21, 2014, 11:04:30 AM »
I did not readjust mine. I rode the bike without the faring and it seemed ok. I have not finished putting it all back together yet. Not planning on changing the adjustment (more loose). Will see how it goes. I think if the bike doesn't hunt then no need to loosen the adjustment,, Right?    Firefighter
1978 Honda 750
« Reply #4 on: March 21, 2014, 03:08:12 PM »
A yr or 2 after I installed mine I had the front tire off and the bars moved front to back. Couldnt tell with the weight of the tire on it. Now if I ever do them again I'm rechecking after 1k miles.
jimmytee
Elizabethtown,KY
« Reply #5 on: March 21, 2014, 09:24:10 PM »
Definitely a good idea cooldude
« Reply #6 on: March 22, 2014, 08:41:41 AM »
If that bike don't hunt, then I'd think you're good to go. If I had a dog like that though, I'd shoot it.
