September 10, 2025, 04:07:22 PM *
Author Topic: Dented Fuel tank....  (Read 4419 times)
YoungPUP
Valparaiso, In
« on: March 23, 2014, 06:08:43 AM »
The wife came in from moving things around in the garage yesterday with a very worried look on her face.  Apparently in her process of moving things on the shelves a quart can of paint fell and hit the nose of the tank in front of and to the left of the fuel fill on the curve of the tank.  It left me with a coffee cup sized dent almost an inch deep.  Do you guys think Daniel's hot glue and a stick trick may take it out or should I just run it down to the body shop to have a stud or two welded on?  THe aftermarket paint cracked all the way around so Its going to need a repaint...  Have never been able to figure out the pic posting process so....  THanks in advance...
99 STD (Under construction)
snakemeister
Alabama
« Reply #1 on: March 23, 2014, 06:27:29 AM »
 YOU DID GIVE HER A GOOD BEATING I HOPE!
« Reply #2 on: March 23, 2014, 06:34:28 AM »
What have you got to lose?  I would try Hot glue, super glue, silicon, 2 sided tape, almost any thing with a slide hammer to try to pop it out before just shelling out money to a body shop.  They can always be you last resort.  Might also try a paintless dent repair guy,
MP
North Dakota
« Reply #3 on: March 23, 2014, 07:12:09 AM »
Ouch!  Sorry to hear this.  It is going to be tough.  An inch deep, in the size of a coffee cup?  Bent bad. You might get it out, but I would think you will need pro help to get it finished nice before paint.
"Ridin' with Cycho"
jmann
Mesa,Az.
« Reply #4 on: March 23, 2014, 07:28:57 AM »
I don't know if I would have the studs welded on. I am in the process of repairing an interstate tank that I bought that I believe had those welded on to pull a dent and when the studs were removed it left behind 2 tiny pinholes. Seller didn't tell me about this repair but after about 6 months of use fuel finally compromised the body filler they used to smooth out the remainder of that dent. That body filler was also covering the 2 pinholes. Needless to say it finally started leaking. I will now be having the pinholes soldered and the tank repainted. My brother had a dent removed on his Harley by the "Paint less Dent Repair" people and I was amazed. They worked out a golf ball sized dent that unlike yours did not crack the paint. When they were done you couldn't even tell it had ever been dented. I was there when they did the work and they just use different shaped spoons to get inside and gently work the dent back out. It cost him $100. Well worth it I thought. You might look them up.
RRS
« Reply #5 on: March 23, 2014, 07:55:54 AM »
I just put a couple of bullet hole decals over the dent and they look natural.
Bugslayer
Lubbock, Texas
« Reply #6 on: March 23, 2014, 09:04:10 AM »
If you want your pics posted, send em to me. I'll post them for you.
« Last Edit: March 23, 2014, 09:51:13 AM by Bugslayer » Logged
Paxton
So Cal
« Reply #7 on: March 23, 2014, 09:07:41 AM »
If it isn't an I/S, you might be better off buying a used one... what colors, what size? ???
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
YoungPUP
Valparaiso, In
« Reply #8 on: March 23, 2014, 09:28:38 AM »
It is a Std tank. Unfortunately the reason the paint cracked is that it was custom paint done by the PO.  The painter is a friend of mine so I was able to get the background on the paint job. Enamel with 4 color coats (2 base and 2 for the flames) and the 6 coats of clear.
Bugslayer
Lubbock, Texas
« Reply #9 on: March 23, 2014, 09:47:33 AM »
Here ya go....
Paxton
So Cal
« Reply #10 on: March 23, 2014, 10:01:44 AM »
As someone else mentioned; here is your fix. It comes in different  colors, sizes, etc! Lips Sealed
http://www.ebay.com/itm/390781913543?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
J. Paxton Gomez
So Cal... 91205
Fritz The Cat
« Reply #11 on: March 23, 2014, 10:17:08 AM »
 Grin
« Reply #12 on: March 23, 2014, 10:23:08 AM »
I bought a bike for my wife that came with a bullet hole sticker over a small ding.
The sticker was far worse than the ding it covered.
YoungPUP
Valparaiso, In
« Reply #13 on: March 23, 2014, 10:25:46 AM »
Thanks Bugslayer!  cooldude
The first pic is enough to make you cry.
The second one is with a can of PVC glue to give you a reference to size.
Once I get the dent fixed then I can address the problem of where to hide the wife's body.  Roll Eyes
« Reply #14 on: March 23, 2014, 10:34:20 AM »
OUCH!   :'(   Embarrassed   Undecided
« Last Edit: March 23, 2014, 10:36:01 AM by salty1 » Logged
My rides:
Paxton
So Cal
« Reply #15 on: March 23, 2014, 10:38:55 AM »
OK. Find the Bullet Holes... Roll Eyes
https://plus.google.com/photos/103917731019176896112/albums/5556072339245085521?authkey=COXVwcj24o7PvAE
J. Paxton Gomez
So Cal... 91205
« Reply #16 on: March 23, 2014, 10:39:35 AM »
That does not look badly creased, and a professional puller may be able to pop it right out.
« Reply #17 on: March 23, 2014, 10:44:07 AM »
Get ahold of the paintless dent repair people.
Go to your car/truck dealer and ask them who does theirs.
I've seen them pull bigger dents than that out of cars and trucks.
They do good work and are very reasonable.
As for where to hide the body, just let her say I'm sorry and forgive her this time. Tell her next time she is DEAD.
Paxton
So Cal
« Reply #18 on: March 23, 2014, 11:10:50 AM »
If you own a human baby, have her go into the tank with her baby armies and pop it out. Roll Eyes
Yes, I have used my neighbor's baby as a tool to retrieve stuff unreachable by my adult hands! Wink
Pretty inexpensive. An ice cream cone does it! 2funny
RIDE SAFE
J. Paxton Gomez
So Cal... 91205
lost
« Reply #19 on: March 23, 2014, 01:00:03 PM »
Paintless dent repair is the way to go. Make sure you find a good one. One of mine had a similar dent and it cost 150. Afterwards you couldn't tell anything ever happened.
NDFRC
Orange Park FL
« Reply #20 on: March 26, 2014, 05:24:58 PM »
so.. with a paintless dent guy.. i am assuming that the tank is off and dry?
jmann
Mesa,Az.
« Reply #21 on: March 26, 2014, 05:51:24 PM »
When my brother had his motorcycle tank done it was on the bike and half full. We met the guy on the way to the Laughlin River Run in the back of an outlet mall where it was quiet. Took him about an hour to complete. He had a generator for powering his lights and a bunch of different tools. Pretty impressive.
YoungPUP
Valparaiso, In
« Reply #22 on: March 26, 2014, 06:10:12 PM »
Talked to 3 body shops  (gas tanks are dangerous blah blah blah) and 2 paintless dent guys. None of them will touch it....  One of the paintless guys said " collectable"  Ive tried the hot glue trick with no luck.  The old body guy neighbor said just stick a welding rod to it and pull it with a slide hammer since the paint is screwed anyway (it cracked all around the dent).  Now what? I can replace it but for some stupid reason a want to save it....
thewoodman
Bradenton, FL
« Reply #23 on: March 26, 2014, 06:49:19 PM »
This might seem like it's outside the box, but look into trying dry ice. Google dry ice dent removal and you'll find links like the ones below, YouTube and all. Let us know how it turns out.
http://www.google.com/#q=dry+ice+dent+removal
TheWoodMan
Valkpilot
What does the data say?
Corinth, Texas
« Reply #24 on: March 26, 2014, 07:42:14 PM »
I had a similar dent.  I worked a lot of it out with hot melt glue (I've got the Billy Mays Ding King), but our tanks are pretty stiff stuff compared to automotive panels these days.
I took it to a local body guy I use.  He tried tack welding studs on, but they would just pop off because he was afraid of burning holes in the metal.  Finally, he cut a round patch and welded it over the dent.  You can't tell now that it's finished and painted.
I've also had a dent removed by a paintless dent guy.  It was relatively expensive and there can be limited success depending on location.  That saddle up the middle of our tanks on the underside makes for some tight spaces inside.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Michvalk
Remus, Mi
« Reply #25 on: March 26, 2014, 08:12:05 PM »
Just a word of warning...I have an Interstate gas tank that now has the shape of a beachball from a painter trying to stick a welding rod to a small dent without cleaning out the tank first. I wasn't there when it happened or it never would have happened. I wouldn't screw around with it until the fumes are inert! JMHO your mileage may vary cooldude
JimC
SE Wisconsin
« Reply #26 on: March 26, 2014, 09:06:09 PM »
Be careful with the weld on dent puller, I had a body shop try that and they blew right through the tank. Then I had to take it to a real welder and get the 3 holes filled.  The valk tank is strong, but it is because of it's shape, not the thickness of the metal. The actual metal is probably not much thicker than an old soda can.
Jim
Jim Callaghan    SE Wisconsin
Rio Wil
« Reply #27 on: March 26, 2014, 09:47:28 PM »
Sand the paint out, fill it using about 3-4 layers of bondo, shape, prime, repaint and forget it.  Won't be any pinholes or anything to compromise the tank integrity.
pancho
Bonanza Arkansas
« Reply #28 on: March 27, 2014, 05:37:01 AM »
At this point, the dent is so severe, that you just need to forget the paint until the dent is removed...... The surface is curved on every side of the dent, it will be a hard one to get right under any conditions. I would continue to call the body shops until you find someone willing to fix it, and worry about the paint later,, maybe the PO will be willing to repair the paint once you have the tank repaired..??
The dent can be removed, and it will be a piece of cake for the right person,,,,, just need to find him.
« Last Edit: March 27, 2014, 05:42:23 AM by pancho » Logged
« Reply #29 on: March 27, 2014, 11:34:08 AM »
So you have 12 gallon capacity now ? Awesome 2funny
« Reply #30 on: March 27, 2014, 02:45:46 PM »
Yea, but the fuel keeps running out of the cracks...  Cheesy
Hay  Cool
Tropic traveler
Silver Springs, Florida
« Reply #31 on: March 27, 2014, 05:59:30 PM »
This is the dent in the side of my '99. Was like that when I bought it. I work at a car dealership & have asked 3 different dentless guys about it. So far 2 of them have said no way, can't get tools in there & apply enough pressure to move the metal. One says $125 & "he'll try".
The paint is not damaged & I have given the heat gun & dry ice method a thorough try with no success.
So bullet hole sticker it is!  Grin Grin
« Last Edit: March 27, 2014, 06:02:42 PM by Tropic traveler » Logged
'13 F6B red for Kim
YoungPUP
Valparaiso, In
« Reply #32 on: March 27, 2014, 06:14:11 PM »
Well since the paint is screwed I've gone on to try a more aggressive method of the Hot glue trick.  I'm currently waiting for the JB weld to dry on a bolt that's attached to the middle of the dent.  I figure worst case I'll have to grind some JB off of the dent....
« Reply #33 on: March 28, 2014, 05:13:16 AM »
I would silicone a bolt with a fender washer on to to that dent and try a slide hammer to pop that out.  Then just rub the silicone off.  It probably will be hard to remove the silicone, but it would e worth it to me to get that dent out.  Kinda lick paintless repair from the Other (dark) side.
pancho
Bonanza Arkansas
« Reply #34 on: March 28, 2014, 09:29:34 AM »
That picture almost makes me sick every time I look at it.....man, you have to forgive her, but she owes you.......
Like Valkpilot related,
"I took it to a local body guy I use.  He tried tack welding studs on, but they would just pop off because he was afraid of burning holes in the metal.  Finally, he cut a round patch and welded it over the dent.  You can't tell now that it's finished and painted."
serious dents require serious approaches for repair. I would be looking for a well seasoned welder to give me a hand with that.
hairyteeth
NW Ohio
« Reply #35 on: March 30, 2014, 12:30:47 PM »
I watched a youtube video of a dent popped with a blood pressure cuff. Might be worth a try. HT
YoungPUP
Valparaiso, In
« Reply #36 on: March 30, 2014, 05:34:23 PM »
Tried popping the dent today with the bolt that was JB welded to the dent. Took the paint right off....  Grabbed the grinder with the roloc pads and took it down to steel.  Have another bolt JB'd to the dent again. try it in the morning...
valkyriemc
NE Florida
« Reply #37 on: March 31, 2014, 07:35:06 PM »
I used a puller about 5(?) years ago with a kit from an automotive parts store. maybe it was "Dent King". Had a dent similar to the silver tank a few posts up. You glue on a puller set up the tripod and pull. Took ten try's but I got it out! Might try search.
More info, searched myself; http://www.valkyrieforum.com/bbs/index.php/topic,22945.0.html
« Last Edit: March 31, 2014, 07:37:11 PM by valkyriemc » Logged
Veteran USN '70-'76
YoungPUP
Valparaiso, In
« Reply #38 on: April 01, 2014, 05:09:20 PM »
Sorry been busy with the asylum I call a job.  Got the dent mostly pulled and already have it glazed with some filler and sanded back into shape.  Just need it to warm up now so I can get it past the primer stage. On the plus side this gave me a reason to fix a rock dent in the front fender and some cracked body work on the shaved tail light.  Ditching the Ford metallic red and corvette orange flames for just straight New Holland Red.  Nice plain and simple.
« Reply #39 on: April 01, 2014, 05:53:52 PM »
Great! Looking forward to pics of the final outcome.  Smiley
My rides:
