November 25, 2025, 11:49:52 PM
Coolant orings
Topic: Coolant orings (Read 823 times)
CISE
Coolant orings
March 23, 2014, 08:08:23 AM »
I am replacing orings on the coolant pipes on top of the engine. The original orings are flat across the top, but the new ones have a raised ridge on one end of the oring.
Does the high ridge go in first or does it go in last?
Re: Coolant orings
March 23, 2014, 10:23:22 AM »
I recently changed out some of these (friends bike) and put them in so the low end of the o-ring went in first followed by the raised part.......they arent leaking
CISE
Re: Coolant orings
March 23, 2014, 11:03:00 AM »
Thanks... getting tired of not riding
deadwood
Albuquerque New Mexico
Re: Coolant orings
March 30, 2014, 07:44:21 PM »
FWIW
Replace mine this weekend.
When I removed the cooling tubes I put the ends with the o-rings under a 10X magnifier and compared them to the new o-rings. I was able to determine they go in with the larger diameter towards the tube and the smaller diameter toward the engine.
Skydive New Mexico Motorcycle Club, Touring Division.
=> InZane XXV
