January 29, 2026, 05:31:36 AM *
Author Topic: back wheel noise  (Read 1888 times)
flash2002
Montreal, Que
« on: July 29, 2009, 10:55:12 AM »
I have a 1998 Valk with 99,000 kms. I was doing a check-up of the bike on a lift,  and noticed, when turning the back wheel by hand that there was a noise (clunk, clunk, clunk) coming from either the wheel or drive shaft. Can this be a problem or is this a normal sound?
SCain
Rio Rancho, NM
« Reply #1 on: July 29, 2009, 11:34:13 AM »
You need to pull the tire and check the following: Left rear wheel bearing, Splines, drive shaft and U-Joint. I would suspect the wheel bearing. Doesn't hurt to just do a routine inspection.
Steve
« Reply #2 on: July 29, 2009, 11:38:43 AM »
A clunk is more like the u-joint.
Pull off the rear brake pedal assy and you can easily slip the boot back and inspect the u-joint.
Didn't you hear anything or feel anything while riding the bike.
That is really strange.
Grandpot
Fort Mill, South Carolina
« Reply #3 on: July 29, 2009, 01:03:21 PM »
Clunk, clunk, clunk, is not a normal sound on a Valk.  You have an issue that should be addressed while you have the bike on the lift.  Sad
flash2002
Montreal, Que
« Reply #4 on: July 29, 2009, 01:32:14 PM »
I figured it might the bearrings or the joint, I will be getting the parts friday, so that way no supprise when I open her up. By the way, the clunk is faint. Thanks for the help.
