February 08, 2026, 03:42:18 PM *
Pages: 1 [2]   Go Down
Author Topic: Throttle Lock  (Read 3279 times)
pancho
Bonanza Arkansas
« Reply #40 on: May 08, 2014, 07:31:33 PM »
You can install the CCS-100 without a vacuum canister as well. I used all except #6 for vacuum when I did my install.
Same here, but I only tapped two of the intake for vacuum, works perfectly.
Do you lose speed when pulling a hill with just the two intakes supplying vacuum?
NITRO
Eau Claire, WI
« Reply #41 on: May 09, 2014, 04:11:41 AM »
Not at all, like I said, it works perfectly. Another member, Alph, did the same and has had the same results (we ride together regularly).
When in doubt, ride.
Pages: 1 [2]   Go Up
