March 14, 2026, 07:16:54 PM *
Author Topic: New Trike  (Read 3742 times)
« on: March 27, 2014, 08:05:31 PM »
Rob or Terry, ya'll get your Trike from the shop yet?
If not, what are they waiting on now?
Enjoy...........
PS:   You will have to add about 9"  to your exhaust tips.
RJC TJC
« Reply #1 on: March 28, 2014, 07:36:40 AM »
 Got it back. They were waiting for a clear deal that they put over the fenders to keep it from getting chipped with rocks. What did you use for the exhaust extensions?
Terry
« Reply #2 on: March 28, 2014, 07:59:13 AM »
I haven't used anything yet.
I'll probably end up getting some 4" slash cut tips and then use the 5" Chrome strap from O'Reilly's to mount them on the existing pipe with.
Then I'll more than likely use a chunk of re-rod welded to the frame at the rear to steady it.
It will basically be the same way I mounted the home made tips on the Chevy Trike.
Right below the firewall, you will see a yellowish strip on the header and muffler.  That is the strip I'm talking about.   Then on the rear of the muffler is a piece of re-rod bent to fit the rear of the curved extension and welded to the frame above it.    Quick and dirty muffler bracket.
« Last Edit: March 28, 2014, 08:03:20 AM by R J » Logged
