November 26, 2025, 12:16:36 AM *
Author Topic: Kuryakyn spark plug covers  (Read 1082 times)
Bota58
Oakland City Indiana
« on: April 01, 2014, 06:27:39 AM »
Hi,has anyone put these on an I/S,the sight says they don't fit an I/S but I've seen some with them on,just wondering what was involved.
Life's Journey is not to arrive at the grave safely in a well preserved body but rather to skid in sideways totally worn out  shouting holy cow what a ride!
« Reply #1 on: April 01, 2014, 07:10:15 AM »
The Kury plug runners for std/tourer fit the IS fine, you may have to loosen the pods to get them underneath, or not.  The IS cut down version has been out of production for a year or two.
wiggydotcom
Yorkville, Illinois
« Reply #2 on: April 01, 2014, 07:29:40 AM »
I've got em on my Interstate. I seem to remember something about it being too long on one side...but either they fit ok anyway or they were easy enough to modify...can't remember which...sorry!
VRCC #10177
VRCCDS #239
Bota58
« Reply #3 on: April 01, 2014, 07:56:59 AM »
Ok Thanks guys
« Reply #4 on: April 01, 2014, 08:27:25 AM »
Aren't they gorgeous?    Wink
My rides:
« Reply #5 on: April 01, 2014, 09:04:47 AM »
The I/S version is the same item, just the length is cut down to accommodate the radiator pods. Or as mentioned, loosen the pods and raise them enough to slip them in place. I just cut mine down since adding pods after I already had them on my Tourer.
A bit of advice; when pulling the plug caps up through the opening on those covers, spray some rubbing acohol on the caps. Makes the rubber slip real easy on metal and leaves no residue.
« Last Edit: April 01, 2014, 09:06:19 AM by John Schmidt » Logged
« Reply #6 on: April 01, 2014, 12:56:51 PM »
A good time also to change your plugs and make sure those plug chambers are clean and the water drain is open. You won't be pulling those Kury covers off very often.  Smiley
My rides:
BigBad1
1999 Interstate
Garner NC
« Reply #7 on: April 01, 2014, 09:05:38 PM »
As already mentioned, they will work on the I/S. You will have to remove the pod to secure it at the front intakes. If you have the fog lights installed in the pods, you will have to trim the front edge of the runner because of the bracket that holds the fog light. I just used snips to notch out the front edge of the runner for the fog light bracket. I spent way too much time trying to trim them to fit exactly around the bracket. Don't worry about it being perfect, the pod covers just about all of the front cylinder and there is no way it can be seen.
fordmano
San Jose, CA.
« Reply #8 on: April 02, 2014, 02:34:17 AM »
Oh my Oh My... I get to share some of my handy work again.
Now keep in mind I do have the pod lights installed so I had to modify mine just a bit or a good fit, very tight but it does fit.
And here is the link too the entire thread... Enjoy.
http://www.valkyrieforum.com/bbs/index.php/topic,21439.0.html
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Bota58
« Reply #9 on: April 02, 2014, 03:51:00 AM »
Thanks for the pics fordmano now I know what I'm doing today!,Great looking bike by the way.
fordmano
San Jose, CA.
« Reply #10 on: April 02, 2014, 09:53:25 PM »
Your very Welcome SIR! And Thank you, I still like her...
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
