November 26, 2025, 12:34:34 AM *
Author Topic: removed drive shaft  (Read 785 times)
Otus
Scott
Taylor Mi.
« on: April 06, 2014, 09:36:39 AM »
I've seen on here a few times that guys have found their pinion cups bone dry, so since I have the rear wheel off I thought I would check it for some piece of mind. What I found looks beautiful, good amount of grease and the teeth look great. I popped it back in and it holds nicely.  My question is, Honda suggests that you replace the stopper ring and the oil seal. Do I need to throw the 20 bucks at it or just remount it and ride it like I stole it? By the way odometer shows 5,800 miles.
« Last Edit: April 06, 2014, 09:40:54 AM by Otus » Logged
« Reply #1 on: April 06, 2014, 09:56:03 AM »
They really don't do much, so, if they look good after installation I don't think I'd worry about them.
I do try to keep parts like that on hand for just such occasions though.
« Reply #2 on: April 06, 2014, 09:57:26 AM »
$20 =piece of mind.
5800 miles? Man you need to ride the dog piss out of it that bike hasn't even worn out a set of tires yet coolsmiley
« Reply #3 on: April 06, 2014, 09:58:12 AM »
Did you check to see if the 2 little holes were plugged up?
They need to be open.
Otus
Scott
Taylor Mi.
« Reply #4 on: April 06, 2014, 10:18:47 AM »
I'll check that RJ, thanks.  Yeah, it used to be someone's garage sculpture.  I'm going to ride it. cooldude
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #5 on: April 06, 2014, 02:18:06 PM »
Checked mine for the first time at 75,000 miles and it was plenty wet and looked brand new. I've been checking it about every 10,000 since.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #6 on: April 06, 2014, 02:27:17 PM »
Says to replace seal if you have removed it from shaft,  if not re-use.
I put original stopper ring on my new shaft.
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
Crackerborn
SE Wisconsin
« Reply #7 on: April 06, 2014, 05:23:53 PM »
I replaced the seal on mine when I pulled mine apart. But I was replacing the yoke so when I ordered it, I also ordered seals, bearings, yaada-yaada-yaada....... No point putting used parts back on when going that far into it.
97 Valkyrie Tour
99 Valkyrie Interstate
