twdurdentwd
« on: April 07, 2014, 04:57:09 AM » |
Can you tell me more about removing the plastic welded baffle from the air box?
Which area does this refer to? What are the results? How is it removed?
00' Valk tourer - 6-6, trigger wheel 00' Valk std - complete build 00' I/S salvaged.. Transplant to std
« Reply #1 on: April 07, 2014, 05:03:30 AM » |
dont do it.......the airbox is best as is
Momz
« Reply #2 on: April 07, 2014, 05:08:43 AM » |
Don't remove the baffle or you will have problems.
I bought an airbox from Pinwall and removed the top airbox baffle just to experiment. It did not go well and I replaced with the stock air box cover. The bike idled much smoother, and seemed to give a better low speed take offs.
It's your bike, so do what you want, others have found that stock is best.
 ALWAYS QUESTION AUTHORITY! 97 Valk bobber, 98 Valk Rat Rod, 2K SuperValk, plus several other classic bikes
« Reply #3 on: April 07, 2014, 05:46:15 AM » |
Like the fellas said, leave it alone ! Honda got it right so don't screw with it. If you don't believe us then make sure you keep what you remove so you can put it back on later.
« Reply #4 on: April 07, 2014, 06:02:56 AM » |
Bad advice to modify the airbox!  Mother Honda knows best in this situation!
« Reply #5 on: April 07, 2014, 07:30:53 AM » |
then I guess my bike shouldn't have been running for the last 30+k miles while giving back 37-40 mpg avg, higher straight hwy riding. yes honda got it right for that Carb jetting/tunning, any airbox mods require new jetting/tunning.
MP
North Dakota
« Reply #6 on: April 07, 2014, 07:31:06 AM » |
Don't do it. EVERY one that I know of that tried it, put it back in! Could NOT get the bike to run decent, unless you do a lot more to it, like CA.
MP
 "Ridin' with Cycho"
twdurdentwd
« Reply #7 on: April 07, 2014, 09:32:47 AM » |
Am I naive to think you can perform mods as long as the carbs are re-jetted?
« Reply #8 on: April 07, 2014, 09:36:27 AM » |
Am I naive to think you can perform mods as long as the carbs are re-jetted?  Not naive but many gone through the same, worked really hard just to get it back to running like it did before the mod only to return to stock and look elsewhere for more power. Some (very few) have reported good results but it didnt sound easy
twdurdentwd
« Reply #9 on: April 07, 2014, 10:54:30 AM » |
Got it - no airbox mod.
DarkSideR
Pueblo, Colorado
« Reply #10 on: April 07, 2014, 12:01:33 PM » |
Want performance Mods?
Find Attic Rat on here. He has a performance package (it isn't cheap) that will get more out of your bike.
2001 Valkyrie Super Tourer VRCC#34410 VRCCDS#0263
quirkyguy001
finally found a way to hold the dragon back
Tulsa, Ok
« Reply #11 on: April 07, 2014, 05:33:24 PM » |
Atticrat takes out the baffle, but that is just the beginning of the mod. He takes out all air flow restrictions. Bottom line is that you have to a complete job. Changes here and there only screw things up. Get the entire mod and look out.
Used to buy new bike every two years. Can't find anything to upgrade to. Harley rider for 40 years. Nough said
