September 10, 2025, 07:04:11 PM
Water pump lube???
Topic: Water pump lube??? (Read 617 times)
Jim500
North Royalton Oh
Water pump lube???
April 09, 2014, 01:36:28 PM »
Is there any problem adding a little water pump lube and anti corrosion additive to the antifreeze?
Re: Water pump lube???
April 09, 2014, 03:16:59 PM »
The water pump bearings are sealed from the coolant. A water pump lube won't touch the bearings until the seal fails. Engine coolants already have corrosion inhibitors. If your coolant is old, just drain and refill with new.
Rio Wil
April 09, 2014, 04:09:46 PM »
Don't think the lube is for the bearings......supposed to lube the seal to keep it from failing....
Jim500
North Royalton Oh
April 09, 2014, 04:54:57 PM »
Yea it is more of a preservative for the rubber parts and a anti acid... Rollaids that's what it needs...LOL
=> InZane XXV
