September 10, 2025, 07:02:37 PM *
Author Topic: Fuel mixture adjustment  (Read 728 times)
Jetflyer
Vale, North Carolina
« on: April 13, 2014, 05:14:44 PM »
I need to tweak the mixture some, based on the look of the plug fouling.
Which way do I need to turn the D shaped tool to lean the mixture (carbs are mounted)?
I'm either driving a Valkyrie or an Airbus... it just depends on the day of the week.
pancho
Bonanza Arkansas
« Reply #1 on: April 13, 2014, 06:20:00 PM »
Just think of it like a screw,, clockwise will seat the needle and lean the mixture.  You may want to start with a carburetor synchronization.
« Reply #2 on: April 14, 2014, 06:55:37 AM »
Do you know what size your low speed jets are? If they are OEM, adjust your pilots to 2 turns out then do the synchronization as recommended.  I'm assuming nobody has messed with the needle valves.
« Last Edit: April 14, 2014, 10:34:03 AM by salty1 » Logged
My rides:
« Reply #3 on: April 14, 2014, 08:55:35 AM »
Plug fouling is rarely the result of ill adjusted idle mixture.
There is a recognized "good practice" for procedures, how to
inspect plugs for running condition.
