April 28, 2026, 07:39:22 PM *
Author Topic: Valve stem replacement.  (Read 2548 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: January 03, 2009, 04:31:45 PM »
I want to replace the valve stems in my Valk, and Jill's Magna, with the bolt-in Yamaha type.  The last time I bought one it was way too small for the hole in the Valk's rim.
Can anyone help me out with a part number or size?
Thanks/
fm
Patron
« Reply #1 on: January 03, 2009, 04:46:58 PM »
Try this link. I have these in all my bikes.  Valk, wing and also the scooter.
http://patchboy.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=17-562&Category_Code=6-3
Hole size is .453"
fiddle mike
Corpus Christi, TX
« Reply #2 on: January 03, 2009, 06:43:38 PM »
Thanks, Patron.
 Jill came home, tonight, with a flat due to a cracked valve stem that was installed last May.  The stems are the main problem we've had with her Magna and my Valk.
Super Santa
VRCC #27029
Houston, Texas
« Reply #3 on: January 06, 2009, 03:18:11 PM »
See this article I posted several weeks back.
http://www.walletpop.com/article/_a/bbdp/suspect-tire-valve-stems-under-recall/273817
Just might have a bearing on your problem.
fiddle mike
Corpus Christi, TX
« Reply #4 on: January 06, 2009, 04:55:06 PM »
Thanks, EB, no doubt  that is contributory since the valve stem in question was installed less than a year ago (May, 2008).    The main cause of the failure, though, is simple physics, I'm afraid.
As you can see, the Magna's  OEM set-up is a problem with some air chucks.
I got around the problem by having a 90 degree stem installed.  The only inner mount style I could lay my hands on was too small, however, so I had to go with what was on hand.  Of course, the Magna rim has no clip to steady the stem, like a Valk rim does ( though I had one fail  even with the clip).
They break in the same place, every time, from whatever you call the force exerted on them while the wheel is spinning, I reckon.
If the only available rubber mount style is coming from China, then replacing them along with the tire is just betting on the manufacturer having a good day.
« Last Edit: January 06, 2009, 04:56:50 PM by fiddle mike » Logged
Krusty
Texas
« Reply #5 on: January 18, 2009, 09:03:16 AM »
I have some Chrome 90 deg stems on my Interstate and have had no problems what so ever. I know alot of Wing riders that have been using these for years.
Jake Wilson.com
http://www.jakewilson.com/typeDetail.do?navType=type&webTypeId=372&navTitle=Motorcycle+Tires+%26+Accessories&webCatId=38
Harold
"Krusty"
Houston, TX
fiddle mike
Corpus Christi, TX
« Reply #6 on: January 18, 2009, 09:54:57 AM »
Jake Wilson.com
Hi, Krusty.  Long time, etc.
Thanks for the link.  I'll be shopping around for a tire for Jill's Magna, soon.
