November 26, 2025, 01:21:19 AM *
Author Topic: Air Box Modifications  (Read 862 times)
DarkSideR
Pueblo, Colorado
« on: April 17, 2014, 09:58:25 AM »
As stated countless times here DON'T MODIFY THE AIR BOX!
The previous owner of my Valkyrie drilled (6) 1/4" holes in the sides of the top of the air box. For two years now I believed that the Valkyries just didn't pull that hard over 4k rpm. Yesterday I plugged those holes and after some research found the previous user also adjust the fuel pilot screws (probably to compensate). I adjusted those back factory (two turns out).
My test run after I made the changes was Eye Widening. The Valk now pulls very hard all the way through the revs. Even bent my back rest in the process!
FYI - I have the Interstate Carb Springs on order and a 4 degree trigger wheel. I am super excited to get those mods made and start riding again with all this new found power. It's like the bike has a new lease on life.
« Last Edit: April 17, 2014, 11:00:54 AM by Joshcornkid » Logged
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
« Reply #1 on: April 17, 2014, 10:13:01 AM »
I would leave the trigger wheel alone, just gonna force you to use premium gas to run right, doubt if it raised performance. JMHO. I gained HP with truck stacks with grumpy's tips over cut piggies and 1/4 inch holes drilled through rear baffles.  Not to loud, not too quiet, Mellow, 6 hp gained, according to dyno run.  Hoser
DarkSideR
Pueblo, Colorado
« Reply #2 on: April 17, 2014, 11:29:17 AM »
Hoser,
I have Super Trapp Exhaust and Headers. Chet from Rattlebars posted some dyno runs when he had the Super Trapp's installed (103hp). He stated better performance with the advanced timing.
I will try it, and pull if I no likey.
VRCC#34410
VRCCDS#0263
« Reply #3 on: April 17, 2014, 02:06:42 PM »
Air box on mine is pure STOCK-NO/NONE/NADA extra holes. Similar to Hoser-piggies cut last baffle drilled STOCK I/S tips. Mellow sound and it shitz and gitz when I twist her tail.  cooldude STOCK trigger wheel. Let us know how your mods turn out please. RIDE SAFE.
« Reply #4 on: April 17, 2014, 08:07:30 PM »
Hoser,
If you get 103 hp, it will be worth the extra cost of premium.do a dyno run and Let us know.  Hoser
