November 26, 2025, 12:35:10 AM
When are changing plug wires?
Topic: When are changing plug wires? (Read 766 times)
Crazyhorse
Hattiesburg, MS
April 17, 2014, 02:37:47 PM »
How many miles before changing plug wires?
3W-lonerider
Shippensburg Pa
Re: When are changing plug wires?
April 17, 2014, 03:12:23 PM »
171,000 still running the original wires, until they go bad I see no sense in changing them
wizard -vrccds#125
Hitchcock Tx.
April 17, 2014, 03:58:05 PM »
When thy short out and give you a problem !
Reach down wile the bike is running. grab ahold of each one ! If you don't get ZAPPED ! Thy are fine
HEHEHEHEHEHE !
April 17, 2014, 04:21:48 PM »
they are solid core wires, the resistor in the end cap can and have gone bad although somewhat rare. I believe the service manual gives an ohm reading to take to check condition.
tank_post142
south florida
April 17, 2014, 09:23:56 PM »
i had one go bad about 350.000 left frt. (serious decrease in power) swapped in a good used one and no problems after that.
I got a rock
VRCCDS0246
Crazyhorse
Hattiesburg, MS
April 18, 2014, 04:15:55 AM »
Thanks for the replies. I only have 138k on my set sounds like they are barely broke in.
=> InZane XXV
