February 08, 2026, 01:56:46 PM *
Author Topic: Still have one intake leaking.....  (Read 850 times)
sawdustar
Conway, AR
« on: April 18, 2014, 05:00:56 AM »
I have only one intake leaking even AFTER the installation of the new O-rings. What else can I do to stop it from leaking and make it right?
BTW, I got new valve stems in like y'all suggested as well as a new front tire and a new General Altimax for the rear. They are installed yet, but I will install them in the next month or so as I still have some decent treat left on the current tires.
Thank You,
Dennis
BonS
Blue Springs, MO
« Reply #1 on: April 18, 2014, 05:11:11 AM »
I'd have to ask if you used something to make sure that the 0-ring stayed in place while the intake was installed? And what is the symptom that you're seeing? What 0-rings did you use? Redeye's or from a hardware store? Maybe they're too small in diameter? Lots of questions, I know, but new o-rings usually fix the intake leaks without issues.
« Reply #2 on: April 18, 2014, 06:23:07 AM »
That is unusual that a new O-ring doesnt fix it.  There are a few things I can think of.  Im just going through what I do whenever I change them things.
-I always use Viton (123) O-rings
-Do one intake at a time so everything stays in place and the same intake goes back where it was
-Clean both surfaces (block and intake) well but gently
-Use a dab of RTV to hold the O-ring in place so it doesnt get out of its groove
-Make sure the intake is sitting FLAT
-tighten the bolts in at least two stages so it goes down flat too
Hope that helps
« Reply #3 on: April 18, 2014, 07:03:47 AM »
Did you replace the OLD O-ring with a NEW O-ring??  Roll Eyes DON'T ASK.  uglystupid2 RIDE SAFE.
« Reply #4 on: April 18, 2014, 08:24:41 AM »
On my first ride after doing it recently, I noticed a bit of seepage on one... I wiped it off
with my finger, and none has come back since...
-Mike "ida know"
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #5 on: April 18, 2014, 10:11:57 AM »
just for giggles  Grin
I would double check the clamps on the airbox tube and intake runner, worked for me uglystupid2   crazy2
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
sawdustar
Conway, AR
« Reply #6 on: April 20, 2014, 11:43:23 AM »
The old o-rings were replaced with the ones I ordered from redeye as y'all suggested. All others that were replaced are doing nicely and no leak. This one is leaking pretty bad. I will pull it off again and check it. I did as ChrisJCMA stated when replacing my o-rings.
Thank You,
Dennis
« Reply #7 on: April 20, 2014, 11:46:30 AM »
What is it leaking ?  Fuel or vacuum ?  Wouldn't happen to be #6 ?
