February 08, 2026, 01:56:46 PM
always mounted lift adpater
Topic: always mounted lift adpater (Read 844 times)
N0tac0p
April 19, 2014, 05:55:53 PM »
put mine on today, and am not thrilled. couldn't get it to align flush with the cross member, it skews a tad. so just concerned the i wont have a vertical alignment when i lift the fat lady. anyone else experience that? is there a fix? should i worry?
jimmytee
Elizabethtown,KY
Re: always mounted lift adpater
April 19, 2014, 07:06:49 PM »
I don't recall an issue with alignment. Been some time,but mine works fine.
donaldcc
Palm Desert, CA
April 19, 2014, 08:57:15 PM »
you should reinstall. had one for about 4 years. as I recall, mine was hard to get flush.
Don
cashman
Goshen Indiana
April 19, 2014, 09:04:45 PM »
Mine has been on for a few years and seems fine. The old gurl isn't the easiest to balance in my experience, but the adapter sure helps!
Lyle Laun
Calgary, Ab
April 19, 2014, 09:56:12 PM »
If it isn't straight, it probably isn't on correctly. I had to mess with mine a bit to get it on. Can't remember what I had to do but it needed a bit of help to get lined up straight.
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
N0tac0p
April 20, 2014, 03:07:51 AM »
biggest PITA is getting someone to balance it while you are pushing, pulling, tightening. cuz once loose your screwed. ideas?
Reply #6 on:
April 20, 2014, 03:34:24 AM »
Quote from: N0tac0p on April 20, 2014, 03:07:51 AM
I put mine in the wheel chock to make it easier...
specialdose
Jonesboro, Ga
Reply #7 on:
April 20, 2014, 03:35:30 AM »
I placed a jack stand under the engine guards to stabilize while installing. Bolted right up, no problems. Use with yellow HF daily to turn around in garage. Do not like backing out. Works perfect.
