February 08, 2026, 01:56:54 PM
dampers
Topic: dampers (Read 720 times)
N0tac0p
dampers
April 21, 2014, 04:47:54 AM »
well the back wheel is off for a new tire, so i am looking at everything. question i have is, "what , if anything , do i use on the 5 allen screws to ensure retention. red, blue, purple locktite? anti-seize?, etc "
Re: dampers
April 21, 2014, 06:17:06 AM »
I haven't used anything, no consequences yet. If anything , I would use blue locktite.
My rides:
Re: dampers
April 21, 2014, 06:31:07 AM »
Blue if you want to get it back off again.
Red if you want it to stay on forever.
Re: dampers
April 21, 2014, 06:44:30 AM »
I replaced dampers in both my bikes. I cannot remember, but vaguely recall the oe bolts may have had honda threadlocker on them. I used nothing. They are not under any particular stress (other than spinning), and have never read of any coming loose.
Punisher
No, not vengenance. Punishment.
Re: dampers
April 21, 2014, 01:27:21 PM »
I buffed the old Honda thread locker off the screws and cleaned the threads in the wheel to avoid messing up the threads. I applied a small amount of Blue Loctite to each bolt and torqued them to 14 ft. lbs.
If you check the OEM manual they want you to install new bolts and those new bolts come with thread locker already on them.
Your existing bolts should be fine as long as the threads are good on the bolt and in the wheel.
