February 08, 2026, 01:57:07 PM *
Author Topic: four quarters worth of grease in the pinion cup...  (Read 994 times)
« on: April 21, 2014, 06:37:07 PM »
The manual says to put .08 oz of grease on the pinion end of the
drive shaft when reassembling... that sounds like just a tiny amount,
and I've always used "just a tiny amount"... and I've had bad luck
and a dry/worn pinion cup a couple of times. I've also had times
when I found everything in perfect shape with the pinion
end of the drive shaft  glistening with final drive fluid.
Last time I weighed the grease out... four quarters worth... that
doesn't seem like much, but it is actually quite a bit more than
just a thin coating on everything like I was doing...
This is what I found this evening...
It got to be dinner time, so I didn't get everything cleaned up, but the flange looks
OK too... there's a tiny wear line, but that's been there for at least three tires or so...
I don't think this sample size of one proves anything, but I do plan to use
four quarters worth of grease in the pinion cup on reassembly  cooldude
I also think I'm going to install one of my "refurbished" final drives, with the
splines stolen from an old 1500 wing final. Wish me luck...
alph
Eau Claire, WI.
« Reply #1 on: April 22, 2014, 03:56:14 AM »
LUCK!!
those splines look good.  i replaced a shaft and pinion cup a couple years back, the two holes on the bottom of the pinion cup were plugged with too much grease.  now when ever i change a tire i check the drive shaft and pinion cup!  plus i've got a spare of each along with a uni-joint!  can never be too prepared!!
MP
North Dakota
« Reply #2 on: April 22, 2014, 05:04:35 AM »
You mean by weight?
Wikapedia says a quarter weighs 1/80 of a pound.
80 qtrs = 1 lb.
.08 oz per qtr = 200 qtrs / lb.
"Ridin' with Cycho"
« Reply #3 on: April 22, 2014, 05:27:48 AM »
You mean by weight?
80 qtrs = 1 lb.
Sorry... I was clearer when I posted about "four quarters worth" previously...
I weighed the grease with a borrowed scale last year. In order to be able to
reproduce a similar amount of grease in the future, I noticed that a stack of
four quarters has a similar volume to the amount of grease I weighed. That's
what my picture is trying to show -  I weighed the grease in one of those
"zero-weight" creamer cups that the people at work adulterate their coffee with,
and drew a line on the cup.
All grease doesn't weigh the same, the little cup does actually have weight and
four quarters is just an approximation.
I was just putting a light coating of grease in the pinion cup before, and this
four-quarter-sized-dab is quite a bit more than I was using... I try to follow the
manual, but don't always have good results. This "four quarter" thing is the
result of my analysis of "what am I doing wrong?"
MP
North Dakota
« Reply #4 on: April 22, 2014, 11:00:25 AM »
Gotcha, Mike.  Figured that might be it.
4 qtrs by wt. would be a bunch!
MP
"Ridin' with Cycho"
« Reply #5 on: April 23, 2014, 12:11:12 PM »
Do what you want, but I'd think when you have an assembly of rear end parts working together for you tire after tire with no problem, I would stick with that assembly as long as it lasted.  Before I did any testing of new/used parts.
Cliches>
Don't fix what ain't broke.
Curiosity killed the cat.
« Last Edit: April 23, 2014, 12:12:45 PM by Jess from VA » Logged
