February 08, 2026, 01:57:00 PM
Brake fluid reservoir viewing window leaks
Topic: Brake fluid reservoir viewing window leaks (Read 821 times)
alph
Eau Claire, WI.
April 21, 2014, 08:19:06 PM »
I’ve got an old Yamaha cycle that I’ve been working on and the front brake reservoir window leaks brake fluid. I covered it with silicone, but now I can’t check the fluid level. So, I scrapped off the silicone, only to find that the plastic viewing window has a hole in it! The plastic its self is brittle.
So, has anyone ever replaced one of these plastic windows? I’m temped to make one out of a piece of Plexiglas since I can not find one online or at the local cycle shops. When I ask the service counter guy if he’s ever done anything like that, he says he hasn’t.
Anyone have any suggestions?
Ride Safe, Ride Often!!
Michvalk
Remus, Mi
Re: Brake fluid reservoir viewing window leaks
April 22, 2014, 01:58:20 AM »
There are probably several bikes that use the same sight glass. Maybe look at different models and find one close, and cut it down. Might find a complete unit at a bike junkyard.
97Valk_CT_Euless
Euless Tx
April 22, 2014, 08:45:29 AM »
I doubt the window was ever intended to be replaced. Whatver you use you'll want to test for a few weeks in brake fluid to make sure it doesn't fog or deteriorate. That's pretty mean stuff. Will be hard to seal also.
Though of pouring it with a clear epoxy? West Systems may work, but I'd test it first.
04strider
April 22, 2014, 06:53:07 PM »
This is a common problem with older bikes, and the suggested solution is to replace the plastic lens with a watch crystal of the same size. Remove the existing plastic window, and find a replacement watch crystal of similar size and epoxy it in the recessed hole.
alph
Eau Claire, WI.
April 23, 2014, 12:02:38 AM »
Quote from: 04strider on April 22, 2014, 06:53:07 PM
that's a good idea! thanks.
April 23, 2014, 12:28:17 AM »
My old Yama-hopper the glass leaked, we messed with it for about 6 months and one day I just stuck a dime in the hole and epoxyied it shut.
Every month or so, I'd pull the cap off and check for dark color or low.
Worked for the last 4 years I had the bike.
