November 26, 2025, 12:40:52 AM *
Author Topic: Coolant plug  (Read 812 times)
Esteban
1998 purchased 4/17/14
Lafayette, co
« on: April 28, 2014, 07:54:03 PM »
I just bought a great looking 98 standard and changing out the plugs(nkg iridium) oil (mobil 1)
Etc... I am having trouble identifying the coolant plug?  I read here that it is the bottom  center 7mm bolt, but the hex nut near it looks like it might be a more likely choice. Any photos or description would help. Also what size are the crush gaskets for these 2 plugs?
Any help would be greatly appreciated!  Tires are next Avons?
It only costs a little more to go cheap
« Reply #1 on: April 28, 2014, 09:19:36 PM »
The coolant drain is at the bottom of the waterpump housing. The wrench size is 10mm. I reuse the washer but seal it with a bit of silicone sealer. Don't over torque it.
« Reply #2 on: April 28, 2014, 09:33:38 PM »
+1 on not over tightening it Undecided don't ask how I know 2funny first time I changed mine snapped that little booger off flush with the water pump housing uglystupid2 can you say JB weld angel now I have to take water pump bolts loose Angry Roll Eyes
« Last Edit: April 29, 2014, 07:56:50 AM by Bighead » Logged
Esteban
Lafayette, co
« Reply #3 on: April 29, 2014, 07:19:14 AM »
Thanks for the tip on tightning, funny how experience is the best teacher.  Will get to it this morning
Can't wait to run up the miles!
« Reply #4 on: April 29, 2014, 04:49:23 PM »
Make sure you use the right coolant. No silicates and mix with distilled water of not buying premix.
