November 26, 2025, 12:39:06 AM *
Author Topic: Belly Tank Fuel Pump question.  (Read 1055 times)
CajunRider
Broussard, LA
« on: April 29, 2014, 07:30:29 PM »
Does anyone know what fuel pump the R&M Belly Tank uses?
Mine has apparently given up the fight... gonna have to change it out.
From what I could find, it's a Facet Purolator "cube" pump...
It this correct?
4 psi or 7 psi (the two options I could find)??
Thanks in advance!!
Sent from my Apple IIe
« Reply #1 on: April 29, 2014, 11:02:30 PM »
I would contact R&M and ask them. Also see what option they might have.
I would replace with one from a Honda MC, a Shadow.
bentwrench
Philadelphia,Pa.
« Reply #2 on: April 30, 2014, 05:35:25 AM »
I picked up a spare from these guys https://www.pegasusautoracing.com/productdetails.asp?RecID=7550
When I first installed mine I had problems with the pump cutting out in hot weather.so i made a heat shield from a 3x5 piece of alum. sheet.I cut two slots in it and attached it to the header pipe nearest the pump.I've had no trouble since,45k miles and going strong.
« Last Edit: April 30, 2014, 08:58:47 AM by bentwrench » Logged
CajunRider
Broussard, LA
« Reply #3 on: April 30, 2014, 06:05:45 PM »
Thanks all!!
I got the exact part number from R&M.  It's the same one listed above.
