February 08, 2026, 10:41:29 PM
Rotella Oil Question
Topic: Rotella Oil Question (Read 1236 times)
Davemn
Minnetrista, Minnesota
May 02, 2014, 09:25:59 AM »
1st oil change on my V Strom. I bought Rotella 15-40 non synthetic (white bottle). I noticed near the bottom it says "Diesel". Is this ok to use???
N8171S
Marlboro, Mass
Re: Rotella Oil Question
May 02, 2014, 09:47:07 AM »
That is all I have ever used in my goldwing, 2 valkyries and BMW R1200C.$12.97 at Walmart. Both Valks are approaching 60,000 miles.
Farther
Quimper Peninsula, WA
May 02, 2014, 09:53:54 AM »
I think that the whole Rotella line is for diesels.
~Farther
May 02, 2014, 10:51:16 AM »
Diesel rated oils have been run in gasoline engines for many many years. There can be some advantages in the additives such as zinc and friction modifiers if you think such things are advantages.
Rotella 15-40 is one of my favorite oils.
Momz
ABATE, AMA, & MRF rep.
May 02, 2014, 04:30:23 PM »
I use Rotella T5 when T6 is unavailable, or just too expensive.
Rotella T5/T6 is better than most "premium" oils on the market.
ALWAYS QUESTION AUTHORITY!
DenverDave
Out past Mars ain't no speed limit -Mojo
May 02, 2014, 09:51:36 PM »
Rotella T6 is rated JASO-MA, and I believe Rotella T5 and regular Rotella are also rated as JASO-MA.
Check the back of your Jug'o oil for its ratings
Quoted from Wikipedia article on motor oils
The Japanese Automotive Standards Organization (JASO) has created their own set of performance and quality standards for petrol engines of Japanese origin.
For four-stroke gasoline engines, the JASO T904 standard is used, and is particularly relevant to motorcycle engines. The JASO T904-MA and MA2 standards are designed to distinguish oils that are approved for wet clutch use, and the JASO T904-MB standard is not suitable for wet clutch use.
These standards, especially JASO-MA (for motorcycles) and JASO-FC, are designed to address oil-requirement issues not addressed by the API service categories. One element of the JASO-MA standard is a friction test designed to determine suitability for wet clutch usage. An oil that meets JASO-MA is considered appropriate for wet clutch operations. Oils marketed as motorcycle-specific will carry the JASO-MA label.
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
Reply #6 on:
May 03, 2014, 05:57:51 AM »
Not a problem! It's good oil!
My rides:
