February 08, 2026, 03:42:21 PM *
Author Topic: Got a gas leak  (Read 2727 times)
Fritz The Cat
« on: May 03, 2014, 06:12:21 AM »
Gas is dribbling out of what appears to be a drain hose under the tank. Any idea what might be going on?
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: May 03, 2014, 06:21:40 AM »
Did you overfill the tank?  On a hot day if I fill mine to the top it will sometime leak out the vent hose when the gas is in the sun.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Fritz The Cat
« Reply #2 on: May 03, 2014, 06:35:15 AM »
Nope, tank is less than half full. It's been sitting for awhile and I just tried for several minutes t5o crank it and she tries to fire but don't run. I fear I've screwed her up bad.  Cry
dan7uk
Louisville, Kentucky
« Reply #3 on: May 03, 2014, 06:37:18 AM »
Sounds like you have a float sticking.  You can try a can of Techron in the gas tank for a simple fix.  But be prepare to tear down carbs for a good cleaning and overhaul.  If carbs have never been touch it's time.  One downfall on Valkyrie is the carbs, must be ridden or carbs will gum up.  Good luck.
Fritz The Cat
« Reply #4 on: May 03, 2014, 06:53:28 AM »
Thanks. Waiting on the dribble to stop so I can roll her back into the garage.  Cry
« Reply #5 on: May 03, 2014, 07:55:32 AM »
It would be good to ascertain exactly where the gas is coming from.
A "drain hose" under the tank isn't very definitive.
It probably is a carburetor but you need to find which one is the culprit.
Be aware you are close to "HYDROLOCK" condition so proceed cautiously.
Usually a tap on the offending carburetor will free up a sticky float and
stop the gas dribble.
A strong dose of additive is strongly suggested.
pancho
Bonanza Arkansas
« Reply #6 on: May 03, 2014, 09:34:04 AM »
What Ricky-D mentioned about the hydrolock...  Take precautions at this point... if it is coming from a float valve sticking in a carburetor, it is likely to be running into the cylinder also.  Turn the petcock off!!
« Last Edit: May 03, 2014, 09:38:59 AM by pancho » Logged
Fritz The Cat
« Reply #7 on: May 03, 2014, 11:15:46 AM »
got her back in the garage. Gonna pull the left side plugs before I try to crank her over again. Do I need to pull the right side also? How hard is it to rebuild the carbs?
Thanx
Mr.BubblesVRCCDS0008
« Reply #8 on: May 03, 2014, 03:56:02 PM »
Stock petcock has a small vent hole on the bottom if gas leaks from there diaphragm in switch has a small hole in it and needs a cover set to repair.  OR you can make it a manual valve very easy.
dan7uk
« Reply #9 on: May 03, 2014, 05:28:56 PM »
Thanx
Good info on carb rebuild
https://www.google.com/#q=d+ray+valkyrie
Fritz The Cat
« Reply #10 on: May 03, 2014, 06:15:59 PM »
I can actually see the hose the gas was coming out of, it's not coming from the petcock.
Thanks for the youtube links. I stumbled upon one of those today gonna watch the rest of them.
If it's a stuck float, what's the best way to proceed? If I can avoid pulling the carbs that would be great.
« Reply #11 on: May 03, 2014, 06:26:55 PM »
If it's a stuck float, try tapping on the float bowl with the handle end of a screwdriver . Works most of the time unless the float needle is screwed up.
Fritz The Cat
« Reply #12 on: May 04, 2014, 05:35:55 AM »
Do I have to pull the tank to get to the float bowls?
Sorry, I'm in uncharted territory.
« Reply #13 on: May 04, 2014, 05:52:05 AM »
Not if you are going to tap them to get them to quit leaking. If you are taking them off yes. I'm no expert but what I have done before that worked is;
1 Turn on the gas
2 determine which carb float is leaking
3 tap repeatedly till leak stops
That said if the float needle is gummed up or damaged it won't work, but it's where I would start. Good luck
Fritz The Cat
« Reply #14 on: May 04, 2014, 06:26:59 AM »
Thanks  cooldude
Brian
Monroe, NC
« Reply #15 on: May 04, 2014, 02:49:49 PM »
I had the same thing once. Techron did not clear it up and could not find what carb was stuck. Tapping did not fix it. I pulled the carbs and cleaned the valve seats and float valves. You could pull the intakes off between the carbs and heads to see if any carb is leaking into the cylinder. I had three that were leaking through between the sides and replaced all the float valves. They are expensive but cheaper than a hydrolock repair. I now close the petcock after each rides as the POS OEM valve was leaking through too. I now have a manual Pingle.
Fritz The Cat
« Reply #16 on: May 05, 2014, 11:39:04 AM »
2 days later and it's still dripping gas. Just went out to the garage and almost passed out. There's a wet spot about the size of a saucer on  the floor. It's a slow drip but a drip none the less. I've never had a problem with the petcock before. Is it the petcock or something else?
« Reply #17 on: May 05, 2014, 11:55:17 AM »
Don't leave it leaking in an enclosed garage. Could be disaster! If its a stuck float turning off the petcock will eventually get it to stop leaking. But you still need to fix it or you could be in for a huge job with a hydro lock . If turning off the petcock doesn't stop it you've got 2 problems
Fritz The Cat
« Reply #18 on: May 05, 2014, 12:08:03 PM »
Is there an easy way to drain the gas tank? i guess that's the first thing I should do.
« Reply #19 on: May 05, 2014, 01:38:20 PM »
Siphon first, then remove the tank and pour out the rest.
Sometimes the stopcock will say "Off" but not actually be "off".
Turning the dial back and forth you can feel the detent for
the "off" position.
No sweat!
Fritz The Cat
« Reply #20 on: May 05, 2014, 01:43:43 PM »
Thanks. There's gas pooled in the low spot of the right head.  Cry
« Reply #21 on: May 05, 2014, 02:09:05 PM »
Do you have any rust in the tank?
It's possible that the vent tube in the tank is beginning to rust through with a small pin hole in it and leaking via the vent hose.
Where exactly is the gas leaking from?
Fritz The Cat
« Reply #22 on: May 05, 2014, 03:59:40 PM »
It's leaking from what looks like a drain tube under the air box. Can't see anything it would connect to so I'm guessing it's a carb overflow line.
I got the tank off. James, from next door, came over and told me the petcock would keep the gas in the tank. Duh! I should have thought of that. Anyway, the tank is off and I'm gonna take the carbs off and go through them.
Wish me luck.  Undecided
« Reply #23 on: May 05, 2014, 04:35:10 PM »
Be patient, working on one carb is tedious. Six can drive you drink.
Fritz The Cat
« Reply #24 on: May 05, 2014, 04:59:42 PM »
Hope I can giterdone so I can ride this summer.  Cry
cajundood
Down in da Swamps of Louisiana
« Reply #25 on: May 06, 2014, 06:36:18 AM »
Thanx
good info on the pull as well as carb teardown......But...it doesn't deal with the fuel rail o-ring replacement or seperating the carbs.  The carbs would have to be pulled off of the bracket in order to get to the plastic tees in between. ANY SUGGESTIONS??  ???
« Last Edit: May 06, 2014, 06:57:30 AM by cajundood » Logged
LIFE's BETTER ON THE DARKSIDE
pancho
Bonanza Arkansas
« Reply #26 on: May 06, 2014, 07:56:35 AM »
Hey Fritz,, First I think you have to identify exactly where or what "leaking from what looks like a drain tube under the air box" hose the gas is coming from before you start tearing your bike apart.  Can you take a picture???   I mean NO disrespect, but if you didn't think to turn off the petcock to stop a gas leak, even after it had been suggested earlier in this post,, do you really want to be tearing the carbs out and apart??   I suggest that first we identify EXACTLY which hose the gas is coming from,, and find the likely culprit before proceeding,  you do want to ride this summer.........
Luck is not what is required here,,, it is a solid troubleshooting approach to the problem.
« Last Edit: May 06, 2014, 07:58:21 AM by pancho » Logged
Fritz The Cat
« Reply #27 on: May 06, 2014, 08:52:24 AM »
When I pull the air box I'll take a pic of the hose.
The reason I want to tear down and rebuild the carbs is because the bike has never run right. I've had idle problems from day one. When I bought her she wouldn't idle at all but after spending a small fortune on Seafoam and other additives, I got her to idle but the idle speeds up when she warms up and if I idle her back down I back to having to hold the throttle to keep her running. I figure the carbs could use a good cleaning, just hope I don't open up a pandoras box.
pancho
Bonanza Arkansas
« Reply #28 on: May 06, 2014, 09:32:11 AM »
Well, from what you are describing, it sounds like the carbs may need to be gone through and get cleaned up, but it is really best to pin things down and know exactly what you are looking at.......  it's the words like hope and luck that give me some concern Fritz........   have you checked out the YouTube videos of the Valkyrie carbs rebuild??  the link has been posted here a couple of times, they are pretty through, but still not to be undertaken unless you have confidence  in your wrenching skills.
First thing is to see exactly where the fuel is coming from..
« Reply #29 on: May 06, 2014, 09:40:56 AM »
Removing the carburetors is not a regular maintenance procedure and can be perilous if you are
not fully capable in this type operation.
Just about every needed chore can be done without removing the carburetors.
Usually not every carburetor on the bike needs attention and time would be better
spent identifying exactly which carburetor is the offender and attend to that
specific carburetor.
Fritz The Cat
« Reply #30 on: May 06, 2014, 12:47:11 PM »
Thanks. I use the words hope and luck because I've never messed with the carbs before. I guess if worst comes to worst I can always pile the pieces into a cardboard box and take it to the Stealer. I did this once with a Toyota. Tried to change the head gasket, got it all tore down and decided I was in over my head. I called a wrecker and had it towed to the Toyota dealer and they put it back together for me.
« Reply #31 on: May 06, 2014, 01:06:50 PM »
If you take off your tank and air filter housing, it would be rather easy to see the leak. Obviously you would need a portable fuel vessel that would supply fuel as your looking for the leak. If you take off the carbs leave the bank in one piece if you can, this assumes the fuel rail Orings are not the problem. You might also want to flush some gas enriched with Chemtool through the float bowls and let it sit for a couple of days. FWIW
My rides:
« Reply #32 on: May 06, 2014, 01:10:39 PM »
Fritz put a call out for local help.? I bet there's somebody that can give you hand. I certainly would if I were close enough.
My rides:
pancho
Bonanza Arkansas
« Reply #33 on: May 06, 2014, 02:42:09 PM »
Same here,,, hate to think of you going down a road by yourself that will cost you a bunch on unnecessarily spent money.   I don't think you will get in over your head if you go one step at a time and ask for advice, or get some help. I am starting to think from the info you provided, that the most straight forward approach to you problem is to remove the carbs as your thinking and clean them,, blow low out the jets and passages,,,  but first,, identify exactly where the gas is leaking from.
Fritz The Cat
« Reply #34 on: May 06, 2014, 03:31:43 PM »
Thanks all for the advice. As far as I know, I'm in no Valk land, nobody near me.  Sad
I'll be asking lots of questions for sure. i also have a copy of the service manual to fall back on and like my neighbor said, take lots of pics as you go.
cokebottle10
Green and Silver 99 I/S
Fletcher NC
« Reply #35 on: May 06, 2014, 03:41:53 PM »
Fritz where abouts are you located.
David in Fletcher NC
Fritz The Cat
« Reply #36 on: May 06, 2014, 05:11:18 PM »
I'm in SE Georgia close to Savannah. Wish I lived in Fletcher, that's God's country.  cooldude
« Reply #37 on: May 06, 2014, 06:33:57 PM »
I'd say there is someone close that can help if you get in trouble. I would still recommend starting with the easy fixes before you tear into it. Good luck
Fritz The Cat
« Reply #38 on: May 06, 2014, 07:03:19 PM »
Thanks. Gonna get started this weekend. Gotta clear all the junk off the workbench before I can even start. Also gotta remember to pull the plugs before I crank her over again in case there's gas in the cylinders.
Brian
Monroe, NC
« Reply #39 on: May 06, 2014, 07:33:14 PM »
Fritz, sounds like you need to replace your jets and pull the pilot needles flushing out those passages and replace the 0-rings and washers. Redeye sells everything you need to do a complete carb rebuild but the jets. Rich gives good directions and use the shop manual. Doing all this smoothed out my idle. Have a well lit and clean area to work and do one carb at a time. Do not touch the synch screws and pay particular attention to how the linkages and the small springs are situated. Take a lot of before pictures to refer to. Take your time. It's not hard, just time consuming. Research this site can really be your friend. Read all you can here and the shop manual first.
Good luck. Keep us posted. I am in Monroe, NC.
