February 08, 2026, 03:41:59 PM *
Author Topic: Engine won't turn Over  (Read 1440 times)
V-SIX DS#121
Western NC
« on: May 03, 2014, 09:45:09 AM »
I have 1997 Valk Tourer and with a new battery new starter switch assy, all fuses good, but engine wont turn over.  Could kick stand switch be bad?  Where is it?  If I jump solenoid it turns over.     Tks
« Reply #1 on: May 03, 2014, 11:30:01 AM »
My guess would be starter switch. Take apart and clean.
V-SIX DS#121
Western NC
« Reply #2 on: May 03, 2014, 11:44:01 AM »
New factory switch.  TKS
« Reply #3 on: May 03, 2014, 11:51:42 AM »
Well maybe you are right about the kickstand switch then. It's down on the stand. Might check your kill switch also.
« Reply #4 on: May 03, 2014, 12:03:39 PM »
In neutral?
V-SIX DS#121
Western NC
« Reply #5 on: May 03, 2014, 12:14:19 PM »
In neutral?
YES
V-SIX DS#121
Western NC
« Reply #6 on: May 03, 2014, 12:15:03 PM »
TKS
« Reply #7 on: May 03, 2014, 03:50:58 PM »
You have how many switches that kill the engine?
The run/off, clutch lever (when bike is in gear) and side stand.
Anyone else?
Could be the tip over also.
Have you done anything to the bike before this, or did it just happen?
« Reply #8 on: May 03, 2014, 04:03:21 PM »
Even with a new battery, have you checked to make sure the ground is solid and clean down low?
Momz
ABATE, AMA, & MRF rep.
« Reply #9 on: May 03, 2014, 06:15:10 PM »
If you pull all six plugs, sit on the bike to keep it upright (with kickstand up), kill switch in the run position,.....now try to see if the motor cranks. If not check the fuseable link at the solenoid and the ground strap at the motor/frame interface.
Good luck
ALWAYS QUESTION AUTHORITY!
« Reply #10 on: May 03, 2014, 06:31:41 PM »
Good luck
Would he be able to jump it at the solenoid if it was a bad ground or fusible link?
Momz
« Reply #11 on: May 03, 2014, 06:46:40 PM »
Good luck
No
« Reply #12 on: May 03, 2014, 07:03:58 PM »
Good luck
No
So it must be starter switch,kickstand switch, tip over switch, or kill switch. At least that's my thinking. Even with a new starter switch I think I would still take it apart and have a look at it.
olddog1946
Moses Lake, Wa
« Reply #13 on: May 03, 2014, 08:20:20 PM »
key on, kill switch set to run?
Every now and then I get nothing,,,then realize if haven't turned the key on....
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
indybobm
Franklin, Indiana VRCC # 5258
« Reply #14 on: May 04, 2014, 05:51:27 AM »
Does your Neutral Light come on with the key on and the trans in neutral?
Does the 'S' light in the tach come on with the key on and the sidestand down
Does it go out when you put the sidestand up
Do you hear a click at the clutch lever when you pull the clutch lever in all of the way?
If the neutral light is on, then the clutch switch and sidestand switch should not matter.
If the neutral light does not come on, then the clutch switch and sidestand switch come into play.
All of this feeds through the Diode Assembly at the fuse block (this also includes all of the associated wiring and connectors).
This is the drawing from Rattlebars showing the interlocks.
http://www.rattlebars.com/valkfaq/schematics/rpage12.html
If you have ever looked at the wiring schematic in the shop manual, you will realize just how good the Rattlebar scematics are!
« Last Edit: May 04, 2014, 06:16:38 PM by indybobm » Logged
So many roads, so little time
VRCC # 5258
« Reply #15 on: May 04, 2014, 08:06:42 AM »
Without a volt/ohm meter you're just blowing in the wind.
V-SIX DS#121
Western NC
« Reply #16 on: May 04, 2014, 10:42:01 AM »
  TKS for the info.  The wiring diagram is great thanks
V-SIX DS#121
Western NC
« Reply #17 on: May 04, 2014, 12:12:37 PM »
   TKS for everyone's help, I'm taking her to the Valkyrie ER.
V-SIX DS#121
Western NC
« Reply #18 on: May 04, 2014, 12:13:17 PM »
  Tks
V-SIX DS#121
Western NC
« Reply #19 on: May 04, 2014, 12:14:15 PM »
   Tks
« Reply #20 on: May 04, 2014, 12:16:21 PM »
Hope you don't get robbed. Let us know how it works out. cooldude
pancho
Bonanza Arkansas
« Reply #21 on: May 04, 2014, 04:57:01 PM »
Thanks for posting that Rattlebars link indybobm,, I didn't know that info was there. I only have the downloadable manual from Dags site,, and the wiring diagrams are hard to make out color cods in the resolution they are in.  I printed out that set.
