February 08, 2026, 03:42:02 PM *
Author Topic: STARTER GONE AND DIED  (Read 904 times)
« on: May 04, 2014, 06:05:07 AM »
Yes I know I have a broken kickstand spring but the kickstand is bungeed up
bike in neutral
it cranks and for the first second it feels like the bike wanted to move
no clunking noise whatsoever so not thinking about hydrolock
BigBF  just rebuilt petcock 3000 miles ago
Does this sound like starter gone bad
What to check  Gman is on the way over now as we were going to do the spring this morning
Have not ridden this bike since completing my trip
dang bike only has around 94000 on it.
Need to order asap to make inzane
« Last Edit: May 04, 2014, 06:06:57 AM by Oss » Logged
MP
North Dakota
« Reply #1 on: May 04, 2014, 06:16:20 AM »
Not quite sure what you are saying.
1.  Starter died, but then you say it cranks.
2.  You say the bike starts to move.    What does that mean?  Why would the bike move.
If it cranks over, but won't start, hook up jumper cables to a car battery, with the motor off.  Try again.
I have had a couple batteries go bad.  Cranks good, but will not start.  Put in a new battery, and all is well.
MP
"Ridin' with Cycho"
« Reply #2 on: May 04, 2014, 08:01:46 AM »
Here, read this thread from last week. It applies to your situation.
http://www.valkyrieforum.com/bbs/index.php/topic,67238.0.html
And yes. Your battery needs to be replaced.
« Reply #3 on: May 04, 2014, 08:08:47 AM »
Well in order of importance
Bike started
Kickstand replaced
Thanks Melvin for the call.  I had the battery on the charger by the time you called
Gman said it sounded starved for gas
Bike has been sitting since April 8th when I returned   I suppose that there was not sufficient
gas in the bowls to start the bike and battery was run too far down.
Its a new battery, replaced over the winter, ran fine all thru my trip
As for the kickstand, the piece of steel hook on the kickstand was sheared off from the incident in Alabama  So using the spring I got from BigMike would not help
Fortunately I had an entire kickstand assembly that I got when I went to cape cod 3 yrs ago and bought the rear end, bags, rails and wheel and final drive off a 2000 blue two tone interstate
We did use the new spring I got from Mike just because its new and the old spring and bolt are in my saddlebag in case a friend has a problem one day
Ricky thanks for the post
BigBF
Text message at 602-332-4872
Phx AZ
« Reply #4 on: May 04, 2014, 04:31:13 PM »
Bike started
Kickstand replaced
Petcock kit from K&L you had maybe K&L P.O.S. ????
Test vacuum and see if it hold or not?
« Reply #5 on: May 05, 2014, 03:45:24 PM »
I thought you used YOUR kit and not mine?
Now I will have to wade thru my parts bag to check out
Thanks for the text on the bolt question, will go to hardware store this week
Hopefully the petcock question will keep till inzane Bill
