February 08, 2026, 03:41:58 PM *
Author Topic: front brake lever travel distance  (Read 1141 times)
Brian
Monroe, NC
« on: May 04, 2014, 02:33:53 PM »
Hello everyone, replace the front pads and decided to change the fluid as it has been a few years and I now own a mity vac to play with. I forgot to pay attention to brake lever operation before the start of this service. Should the brake lever feel like the clutch? Meaning it has resistance at the start. The front brake seems to be easier and does stop hard about 1" from the hand grip. I tried moving the bike back forth the brakes are grabbing and holding tight. I researched this subject here to find that air bubbles get trapped at the fittings. I have pulled a whole new bottle of fluid thru both calipers and still the same. Can anyone got check theirs and report back?
Thank you,
« Reply #1 on: May 04, 2014, 07:17:02 PM »
Sounds normal to me.
wiggydotcom
Yorkville, Illinois
« Reply #2 on: May 04, 2014, 09:47:23 PM »
Brian,
Just went out and checked mine. The very end of the lever(where the "ball" is) moved about an
inch inward to where the brakes grabbed. It still had plenty of clearance between the closest spot of the lever and the throttle housing.
VRCC #10177
VRCCDS #239
Brian
Monroe, NC
« Reply #3 on: May 05, 2014, 02:47:04 AM »
I appreciate guys. Thank you.
« Reply #4 on: May 05, 2014, 05:40:38 AM »
Thats about the amount of free travel you should have. If the lever pressure is good and hard you should be air free and good to go.
Brian
Monroe, NC
« Reply #5 on: May 06, 2014, 07:09:57 PM »
I noticed coming home from work today that with the outside air temp around 90 degrees the front brake lever had less free play in it. I plan to measure it tomorrow morning before heading out and then when I get back home. The difference is somewhat noticeable.
« Reply #6 on: May 07, 2014, 08:11:11 AM »
The important thing is to assure that the brake pads are not dragging
on the rotors. Air in the system can cause unintended drag.
Now, also, you have to realize that the brakes, because of the design
will have the pads rubbing on the rotors most all the time, but they
should not be dragging, since this will cause a heat buildup.
Brian
Monroe, NC
« Reply #7 on: May 08, 2014, 02:28:51 AM »
Ricky-D,
I do not notice any difficulty moving the bike. I suppose to know for sure if they are not dragging is to lift the front wheel to turn it by hand? Thanks for the tip.
