March 15, 2026, 06:12:37 AM *
Author Topic: Florida gang gets dibs.  (Read 1636 times)
« on: May 04, 2014, 06:39:18 PM »
I recently rebuilt a set of front brake calipers for a Valkyrie with the thought I'd use them on the GL1200 project. As fate would have it, I can't use the Valk wheels so I'm going with the 1200's OEM wheels, brakes, etc. Now I have a set of calipers with new pistons, seals, brake pads and cleaned up pretty good. All items lubed as needed and a couple new boots for the pins. They also have the mounts so all you'd have to do is disconnect the brake line and pull the two mounting bolts. Put these on, connect the brake line and bleed'em out. Asking $175 shipped. If nobody needs them I'll post this on the Classifieds but wanted to give you guys the first shot. Here's one picture, I have a couple more.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #1 on: May 05, 2014, 02:46:16 AM »
John,
 If these are still available, consider them sold. (PM sent)
-Doug
« Reply #2 on: May 05, 2014, 06:05:29 AM »
John,
-Doug
Got it. Do you have a PayPal account? Talk to you this evening.
