February 08, 2026, 03:42:03 PM *
Author Topic: Carb Balance Question?  (Read 2664 times)
da prez
Wilmot Wi
« on: May 05, 2014, 07:56:16 AM »
  I balanced the carbs using the info in the tech section. They said to use a four gauge system. I want to make a six gauge system so I do not have to switch gauges . Is there a reason to only use the four gauge system.
                              da prez
JC
The Beast
Franklin, TN
« Reply #1 on: May 05, 2014, 09:44:33 AM »
All I can think of is that 4 is less expensive than 6. Having 6 gauges would certainly make it quicker and easier. I user a 4 gauge set myself.
Joe Hummer
Arnold, MO
« Reply #2 on: May 05, 2014, 09:57:42 AM »
Absolutely no reason a 6 gauge system won't work.  I have a 1 gauge system on a manifold.  I clamp off the cylinders don't want to read and read the one I want to.  Make all connections before the bike gets terribly hot.  cooldude
Joe
1999 Valkyrie Interstate
« Reply #3 on: May 05, 2014, 10:38:35 AM »
Six is the easiest way to synchronize the carburetors
signart
Crossville, Tennessee
« Reply #4 on: May 05, 2014, 05:10:29 PM »
I like one good gauge and six aquarium valves. Also below gauge I have a valve to eliminate needle bounce.
Brian
Monroe, NC
« Reply #5 on: May 06, 2014, 07:46:39 PM »
+1 on only using one gauge. 6 gauges will all read different as each one is not built exactly the same. I know this from a previous life where I had to calibrate gauges used high pressure equipment. You are only comparing each carb to # 3 regardless of what the vacuum is. I too use a set up like signart is showing here. Works great. While you are at the fish tank store get the silicone air tubing. This stuff is really pliable.
« Reply #6 on: May 07, 2014, 08:06:23 AM »
Brian writes:
You are correct there Brian. I realized there would be such a problem when I purchased
the gauges, so I bought ten gauges. They were very inexpensive, less than 5 bucks each
and it took all ten to get six that matched. I hooked the all up to a common manifold to
get six that were the same. I had priced those little aquarium valves and found them
very pricey!
And finally, the convenience of having the ability to see all six continuously makes
comparing very easy.
Tx Bohemian
Victoria, Tx
« Reply #7 on: May 07, 2014, 08:09:19 AM »
I agree here, although you'll probably get flamed from the "multi-gauge" advocates here!
I too deal with "certified" gauges that have to be calibrated on a certain frequency.
So unless you're using calibrated gauges the carb balancing quite possibly will be off.
I use the "one gauge, "Y" connection, and a couple of hemostat clamps" method.
Al
« Reply #8 on: May 07, 2014, 08:14:10 AM »
I use one guage and don't need  to calibrate a multiple gauge system.
My rides:
signart
« Reply #9 on: May 07, 2014, 11:03:05 AM »
I went ahead and invested in a very good gauge for my set up as I can disconnect it and use it in my truck hobby which I do often. Before I use it on my Valkyrie again, I will invest in some better hoses as these get very soft from the heat and could potentially collapse or come off during the procedure.
Now that I am more familiar with the procedure, I would be a lot quicker, but I suggest removing the alternator cover as a precaution. Also a fan in front of the radiator.
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #10 on: May 07, 2014, 05:56:15 PM »
here is a link on Ebay for a 5 way manifold. I use 2 gauges. The first one is the reference and the secon is used through the manifold to read all 5 other intakes one after the othe without having to disconnect anything
http://www.ebay.ca/itm/290934854031?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Have a safe ride
whitestroke
San Pedro, Ca.
« Reply #11 on: May 09, 2014, 11:09:00 AM »
Here's my 6 gauges
https://www.youtube.com/watch?v=1imfVbe9V7w
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Chillerman
Golden, CO
« Reply #12 on: May 09, 2014, 11:57:09 AM »
No calibration of gauges necessary.
« Reply #13 on: May 09, 2014, 12:52:43 PM »
Traveling Red Cross blood donor contraption?   Grin
Brian
Monroe, NC
« Reply #14 on: May 09, 2014, 05:20:50 PM »
Here is my set-up. Using an old vacuum/pressure gauge that I had from working on older cars and trucks.
