February 08, 2026, 03:42:13 PM *
Author Topic: adjusting handlebars  (Read 1303 times)
Cruiserman
« on: May 05, 2014, 05:27:04 PM »
Has anyone came up with a way to remove the chrome caps that cover the heads of the bolts for allowing you to adjust the handlebars WITHOUT buggering up the aluminum dog bone?
    Trying to be real careful using a small screwdriver but no success. Keeps wanting to scar the soft alum. edges of the holes  Angry
I feel more like I do now,than I did a while ago.
six2go #152
Ft. Wayne, IN
« Reply #1 on: May 05, 2014, 05:36:28 PM »
I just used my fingernails.
Cruiserman
« Reply #2 on: May 05, 2014, 06:05:05 PM »
wow Six2go,i can't budge mine with a screw driver. prying just wants to jimmy the alum. dog bone up
8Track
Adelaide, South Australia
« Reply #3 on: May 05, 2014, 06:07:14 PM »
Put a cloth down between your prying implement and the dog bone!
« Reply #4 on: May 05, 2014, 07:36:33 PM »
Use the blade of a knife. I raise it just enough with a knife blade to slide a small driver under to remove the cap.
My rides:
Cruiserman
« Reply #5 on: May 06, 2014, 04:28:46 AM »
 cooldude  Got em off! Thanks you guys for the suggestions,the knife worked pretty good.
  I was  digging too deep,thinking it was a much larger/deeper cap AROUND the head of a hex headed bolt,i was wrong,it has allen head bolts with the cap pressed into the head of the allen hole. Again
a big THANKS!  " Ride Safe"      Dan
« Reply #6 on: May 06, 2014, 08:31:57 AM »
I realize you have figured it out already BUT I have a long awl that had the tip bent when I lived in Illinois MANY moons ago.  Wink THAT slight bend is PERFECT for removing those little chrome plastic plugs you describe as they are also used on the fork axle clamp bolts. The longer I am on this board the more impressed I am with the help and the been there done that experience to help folks out so we can get out and RIDE.  cooldude cooldude cooldude cooldude RIDE SAFE.
Promagnaman
North Dakota
« Reply #7 on: May 06, 2014, 09:16:07 AM »
Those little caps can be replaced.  You can get chrome or black I think. Different sizes too. Places like MACS Hardware etc have them...
