February 08, 2026, 05:32:54 PM *
Author Topic: Battery Install Trick  (Read 1835 times)
ShiftHappens
South Suburbs Chicago, IL
« on: May 06, 2014, 11:48:09 AM »
I had a hard time installing my new Yuasa battery. Here is what I found on Google.
Important trick to installing a motorcycle batterypowered by Aeva
That ended my frustration and I thought i'd pass it on.
1999 Interstate
« Reply #1 on: May 06, 2014, 12:03:58 PM »
That's a great idea.
I took my battery out while on the road last year, and had
the same trouble, ended up using a bit of cardboard instead
of the tubing... (thanks Gordon...)
I like my Yuasa, but I noticed that the battery they have that
fits our bikes at Advance Auto Parts has a selection of nuts for
the bolts... one of the nut choices is very thick... that
would have solved the problem...
Paxton
So Cal
« Reply #2 on: May 06, 2014, 12:05:29 PM »
Good trick. Thanks for sharing.  coolsmiley
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
bassman
« Reply #3 on: May 06, 2014, 12:11:24 PM »
Good idea....I used to use a flat rubber band doubled the same way but think this method might be a little easier.....
« Reply #4 on: May 06, 2014, 12:46:34 PM »
I've been using the head of Q tips to do the same thing, but I'll be using the tube trick in the future.
My rides:
98pacecar
« Reply #5 on: May 06, 2014, 03:15:13 PM »
Piece, of a popsicle stick,,,,, fer me....    cooldude
Pappy!
Central Florida - Eustis
« Reply #6 on: May 06, 2014, 03:34:05 PM »
Toothpick....but I like the hose a lot better
« Reply #7 on: May 06, 2014, 03:40:43 PM »
That's a good reminder. I learned that trick a few decades back and posted it here a few times over the years. But a refresher on a simple idea is worth the time spent. Thanks....and I also prefer using a piece of the hose. I have a set in there now that must be at least 10 yrs. old.  cooldude
« Reply #8 on: May 06, 2014, 05:38:47 PM »
Does this mean you are not supposed to hammer the post down to fit flush with the skinny nut?    Roll Eyes
The best part of this little exercise is that the skinny nuts stay in place.  Who hasn't slid them in, lifted it into place, begun to wiggle it in and a skinny nut falls out to become lost down in the bike in another dimension beyond space and time?
Hey Rod Serling, give me my nuts back.    tickedoff
Brian
Monroe, NC
« Reply #9 on: May 06, 2014, 06:35:48 PM »
I have used small pieces of black foam pipe insulation or weather stripping. I will try this next time.
« Reply #10 on: May 07, 2014, 11:03:47 AM »
Really, this is really a common problem?  I just stick the little nut in there and "find it" with the bolt and screwdriver.  Never even thought of it as even a potential problem, it just goes on.
Just seems much to do about nothing to me...
« Reply #11 on: May 07, 2014, 11:52:04 AM »
It is usually when ya got way toooooo many wires attached to the battery.
« Reply #12 on: May 07, 2014, 12:20:58 PM »
I just had one set (one wire to hot, one wire to ground) of wires - this:
I have a different set of wires now...
I guess it is only a non-issue for you guys with stone stock bikes  Wink
kyrie6
« Reply #13 on: May 07, 2014, 12:24:31 PM »
I ve  used elec. tape.  BUT I got a battery last week from a distributor friend was  a second no name  on it. Which orig, is DEKA or ?  BUT, it had the posts threaded for the bolt.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #14 on: May 07, 2014, 01:54:57 PM »
I too have always just used a small screwdriver to lift the nut up to make contact with the bolt. Nice idea though  cooldude
BigChris99
Hesperia CA
« Reply #15 on: May 08, 2014, 03:52:50 PM »
DEKA's are good batteries. Don't have a clue who makes them. Us with KLR's like em a lot. I just bought a new one for said KLR.
In 5th gear.... looking for 6th
VRCC # 35023   IBA # 7849
Earl in Pensacola
« Reply #16 on: May 09, 2014, 05:48:58 AM »
I'm one of "those guys" with way too many wires attached directly to the battery.
My solution=   I use 1/4" longer bolts!!  Done deal-never looked back!!
lljjmm
« Reply #17 on: May 09, 2014, 08:25:59 AM »
I use silicone to  hold the nut in place, that way it is always stuck in the right place and position.
Before I install battery, I first screw bolt into battery nut (which is in place on the battery ) to ensure contact and that the nut is up tight in the holder, tighten up slightly, then put silicone around the nut (in the slot area) - let cure.
Then install into bike. Never lose a nut again and in the right position.
« Reply #18 on: May 09, 2014, 08:34:10 AM »
I like that idea.   cooldude
Even though I've never had any real corrosion grow in my bike batteries (like my car batteries), that would seem to take up any room for corrosion to grow in that little pocket.  Have always used plenty of dielectric grease, but silicone may be better yet.
« Last Edit: May 09, 2014, 08:36:52 AM by Jess from VA » Logged
Farther
Quimper Peninsula, WA
« Reply #19 on: May 09, 2014, 08:54:08 AM »
Really, this is really a common problem?  I just stick the little nut in there and "find it" with the bolt and screwdriver.  Never even thought of it as even a potential problem, it just goes on.  Just seems much to do about nothing to me...
+1, I didn't know it was a problem until now.
~Farther
BonS
Blue Springs, MO
« Reply #20 on: May 09, 2014, 09:53:18 AM »
Most readily available dielectric greases are silicone based so you're fine.
« Reply #21 on: May 09, 2014, 01:26:49 PM »
It just drops in place fer gosh sake.  There a lot harder parts to install.  I never noticed any problem installing a battery.  The Alternator or U-joint, now that's a different story!  Shocked  Hoser  Smiley
« Reply #22 on: May 09, 2014, 01:47:32 PM »
What can I say, some of us are just helpless and inept...
-Mike "all batteries aren't exactly alike"
« Reply #23 on: May 09, 2014, 01:53:02 PM »
John, you are one of the few that doesn't have a crap load of wires attached to the positive post.    That has a tendency to make the bolt too short.
« Reply #24 on: May 09, 2014, 05:13:57 PM »
I only have one, it runs to the  fuse strip and distributing buss where the tool kit used to be. The terminal on the post has a bolt a hair bit longer to reach the nut.  Hoser  Wink
« Reply #25 on: May 09, 2014, 07:02:41 PM »
AHA!
-Mike  Smiley
Stanley Steamer
Athens, GA
« Reply #26 on: May 10, 2014, 06:52:20 PM »
I'm going to use that trick tomorrow. ..got my new Yuasa delivered yesterday. ...got the acid in, let it soak into the lead plates for an hr per the instructions. ...checked the charge...18.8 volts.... Shocked.....instructions said to give an initial charge of 1.4ah for 5-10hrs, or a 6amp charge for 1 hr for the quick charge. ..my charger has a 2,4,6amp setting. ..used a 2amp setting and 3 hrs later the charger said it was full......rechecked the charge,  and it was still 18.8 volts...that seems high to me for a "12" volt battery.....or else I need to use a different voltage tester??
« Last Edit: May 10, 2014, 06:54:06 PM by Stanley Steamer » Logged
Stanley "Steamer"
"Ride Hard or Stay Home"
