February 08, 2026, 03:42:11 PM *
Author Topic: 4 way trailer light wiring.... help needed.  (Read 729 times)
Builder630
Chicago
« on: May 07, 2014, 07:17:22 PM »
Ok, I'd like to say that I did use the search button, however I'd like a direct answer from someone that did it....
I have a 99 Interstate and I just bought a tent trailer with a flat 4 pin harness. I started to wire it in and realized that the turn signal wires and brake light wires are separate. So.... How do I do this without wiring a separate wire just for the brakes? THANKS IN ADVANCE!
tank_post142
south florida
« Reply #1 on: May 07, 2014, 08:19:29 PM »
this works good. do a check on ebay:
http://www.ebay.com/itm/141107590269
I got a rock Sad
VRCCDS0246
« Reply #2 on: May 07, 2014, 09:09:29 PM »
You need a trailer light converter like the one Tank linked to.  Make sure it is one that takes power directly from the battery rather than overloading the bike's light circuits.
« Reply #3 on: May 07, 2014, 10:18:17 PM »
You need a Hoppes 5-4 powered trailer converter. Part # 46255. I have one on each bike. They have worked well for years.
