February 08, 2026, 03:42:20 PM *
Author Topic: Interstate truck removal help and rear fender tail light.!  (Read 929 times)
nswiley
« on: May 07, 2014, 07:40:56 PM »
Want to remove my trunk on my 200 interstate,> will the wires going to the tail lights in the trunk easily attach to a a fender light. And where do I find a fender tail light,? Thanks for all the help!
tank_post142
south florida
« Reply #1 on: May 07, 2014, 08:14:26 PM »
http://www.ebay.com/itm/121336233404?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
you will need to run a set of wires from behind the right sidecover inside the fender to the tail light
I got a rock Sad
VRCCDS0246
nswiley
« Reply #2 on: May 08, 2014, 03:48:21 AM »
Thanks!
Pete
« Reply #3 on: May 08, 2014, 06:45:36 AM »
Order the light and the wiring pigtail for the standard.
Any Honda parts supply.
« Reply #4 on: May 08, 2014, 11:54:13 AM »
Parts list.  Dated info.  Prices may be higher, parts should be the same #s.
http://forums.delphiforums.com/valkyrie/messages/?msg=11596.1
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #5 on: May 08, 2014, 12:59:25 PM »
Big BF (Bill Furgeson) has a picture 'How To' on making the IS trunk a 'quick release'...  Check this link.
I did this when I put an IS trunk on my Standard...
http://www.bigbf.com/bigbf_shop/mod_i-s_trunk/
Black Dog
Don't you know...
« Reply #6 on: May 08, 2014, 08:42:21 PM »
There is 2 wire harnesses that are different between the IS and the Std/Tourer, but both plug into the same main wire harness.
I believe they are labeled sub-harness A & B.
One stays with the fender, and the other goes from the main to the rear harness.
The IS has 3 harnesses, one end for the trunk lights, the other for the tail light, and the interface.
