February 08, 2026, 05:32:24 PM *
Author Topic: Rear speaker harness  (Read 843 times)
gatorvalk
« on: May 11, 2014, 09:17:45 AM »
I just bought a 1999 interstate I,m try to find the harness that runs from the Radio harness to the speaker. the harness  starts under the right side of the side cover and goes to the speakers. i have gone to the shop and the micro fish has nothing listed.
« Reply #1 on: May 11, 2014, 01:25:08 PM »
Check Electricalconnections.com  .... He probably makes one. I added rear speakers for my '05 Wing. Bigbikeparts.com sells a harness for a wing. Check them too.
bikerboy1951
Grand Forks, ND
« Reply #2 on: May 11, 2014, 02:36:22 PM »
Electrical Connection does have the harness.  If you want to install as per Honda I have a copy of the instructions that a fellow from Honda emailed to me.  I did the install following the instructions and am very happy with it.  Others drill through the box to do the install, so there are options.  If you buy the harness from EC it will not be long enough to do the through the box install.
Brad
saab9k
« Reply #3 on: May 11, 2014, 03:58:27 PM »
I would like a copy too planning on adding rear speakers on 1999 Valkyrie Interstate.
« Reply #4 on: May 11, 2014, 04:58:47 PM »
I bought a set from advice from someone here (cursed if I can remember  uglystupid2) but the were plug and play just had to drill a hole to get wires into speaker box of armrest and I did that inside the trunk so it can't be pinched when closing.
saab9k
« Reply #5 on: May 11, 2014, 05:52:22 PM »
Brad
Thanks. Got the instructions in email.
PhredValk
Edmonton, Alberta, Canada
« Reply #6 on: May 11, 2014, 07:01:20 PM »
bikerboy1951, I've already installed the harness, and you are right, too short. I'd like to see the instructions as well as mine came with none.
Fred.
falliston@gmail.com
VRCCDS0237
« Reply #7 on: May 11, 2014, 07:12:40 PM »
The harness I bought was a touch too long I will search and see if I can find where I got it.
