February 08, 2026, 05:32:30 PM *
Author Topic: If it's not the cable, what is it???  (Read 1163 times)
biguglyman
Brockport, NY
« on: May 11, 2014, 10:16:59 AM »
Speedometer quit on me a few weeks ago. Finally got around to replacing the cable. Still doesn't work? Next step?
« Reply #1 on: May 11, 2014, 10:29:57 AM »
I'm assuming it is a STD or Tourer.
Did you check the gear on the front wheel?
They can get screwed up pretty easy on a tire change and etc.
« Reply #2 on: May 11, 2014, 01:23:04 PM »
The drive gear on the axle is plastic. Pull the wheel and check it. I regrease it with every tire change.
« Reply #3 on: May 11, 2014, 01:58:01 PM »
Its one of 3 things
1. cable
2. drive
3. speedo head
Like the guys said, its probably the drive. Has the front wheel been off recently ?
98pacecar
« Reply #4 on: May 11, 2014, 02:51:42 PM »
I check the wheel drive unit by mounting the cable to it and leaving the top end off the speedo.  coolsmiley
Secure it to something so yer lookin right down at the end..
Then roll the bike a few feet n' see if the cable is turnin at all?
Lets ya know zactly,, where,,,,, da problem is..............    Wink
biguglyman
Brockport, NY
« Reply #5 on: May 11, 2014, 05:04:16 PM »
Front wheel has not been off since I bought the bike a couple years ago. I'll try pulling it back off the speedo and then rolling it forward to check cable operation. How hard is it to replace the speedo part? Can I just replace a gear or something?
nogrey
Nampa, Idaho
« Reply #6 on: May 11, 2014, 08:42:03 PM »
Unscrew the cable from the back of the speedo. See if you can spin it. If you can, cable or gear is broke. If not, it's the head. Cable and gear are replaceable. Easy peasy.
« Reply #7 on: May 12, 2014, 05:06:02 AM »
He already replaced the cable. Yes either are easy and the hardest part about changing the head will be paying for it coolsmiley
biguglyman
Brockport, NY
« Reply #8 on: May 13, 2014, 03:26:10 AM »
Where would I look for a speedo head?
« Reply #9 on: May 13, 2014, 05:37:54 AM »
Pinwall Salvage.
98pacecar
« Reply #10 on: May 13, 2014, 06:15:48 AM »
Or here..... $55.06 new
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500CT+A/FRONT+WHEEL/parts.html
Didn't know what year yer bike is,,, pulled up the 98 ...    Wink
« Reply #11 on: May 13, 2014, 10:55:41 AM »
So, you replaced the cable ? Was it broken ?
It hard to see if the drive is working just by moving or spinning the wheel by hand. Disconnect it from the head and go for a ride. If the cable then turns, the head is bad. Since the cable is new [and if its installed correctly] and if it doesn't turn then the drive is bad.
Don't over tighten the drive retainer screw.
biguglyman
Brockport, NY
« Reply #12 on: May 13, 2014, 12:26:33 PM »
I just assumed it was the cable and ordered one. Drive on front wheel looked good when I replaced the cable. I think it's the speedometer itself.
