February 08, 2026, 05:32:29 PM *
Author Topic: Clutch noise  (Read 1425 times)
hoosier jaybird
NE IN.
« on: May 11, 2014, 05:50:42 PM »
Has anyone had the bearing in the clutch lifter plate ( throwout brg) go bad? I still have a roughness and noise coming from the clutch area until I pull in the clutch lever and then it gets quiet and the roughness goes away. It seems that when you put tension on the throwout brg so that the clutch disengages is when the noise would manifest itself. But not so. I have pulled the slave cyl and lubed the pushrod but that didn't make any difference. Running in oil it seems the brg wouldn't go bad, so any one had issues with it? Thanks for any input here. Jaybird.
« Reply #1 on: May 11, 2014, 05:52:57 PM »
Is this only when idling in neutral?
hoosier jaybird
NE IN.
« Reply #2 on: May 11, 2014, 06:35:19 PM »
Well, I hear a noise similar to that on the road so I am wondering if that could be where it is coming from. I have tried pulling in the clutch and coasting to see if any change and also pulling in the clutch and hitting the kill switch while moving but can't seem to tell much change. I recently did the rear end lube maintenance and pulled the u-joint with all looking ok. The wheel brgs were smooth front and rear, not too loose and no catches. I am not sure about tire noise though, just put on Dunlop E3s.
olddog1946
Moses Lake, Wa
« Reply #3 on: May 11, 2014, 06:45:59 PM »
Had a set of E3's on my GW, they were the loudest tires I've ever had on any bike I've owned.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
hoosier jaybird
NE IN.
« Reply #4 on: May 11, 2014, 06:57:34 PM »
To answer Bigheads question, the noise and roughness is very evident at idle in neutral. I was wondering if that throw out brg has failed for anyone. And I do wonder about those E3 tires as road surface changes also changes the noise somewhat. I have a ride to Kansas over memorial day weekend and Inzane right on the heels of that. So no nasty surprises wanted.
Michvalk
Remus, Mi
« Reply #5 on: May 11, 2014, 07:07:19 PM »
I don't know if there is a true "throwout bearing". Most Valks make some noise at idle with the clutch out and in neutral. But, I have never heard any clutch noise in gear and running down the road. There is some gear 'whine" while moving. cooldude
« Reply #6 on: May 11, 2014, 07:11:17 PM »
As Mitch stated both of my Valks in neutral at idle kinda make a rattling sound but when you pull in the clutch lever that smooth out. My 97 (I bought it new) has done it since day one and is more pronounced than my 99 IS. But hear no noise under load other than the tranny whine that they all have.
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #7 on: May 12, 2014, 04:54:45 AM »
  Rivets
Highbinder
Bastian/Tazewell,VA.
« Reply #8 on: May 12, 2014, 02:06:03 PM »
I have a 97 that does the same thing, loud  whirling bearing noise while idling in neutral, the minute  you slip it in gear it goes away...there is no throw out bearing, the only thing I thought it might be is the small bearing at the rear of the transmission where the slave cyl. connects, you would have to remove the back plate on the trans to replace it...me I've been living with it for about  a year now with no problems, I figure if it lets go I'll replace it then...
hoosier jaybird
NE IN.
« Reply #9 on: May 12, 2014, 05:11:25 PM »
Highbinder and Bighead, thanks for your experience and input. Sounds pretty much like mine, so since no one has had issues with the bearing I am suspecting the noise is from the tires or something that may be vibrating. Puts me to ease that it may well not be mechanical. Jaybird.
