February 08, 2026, 05:32:55 PM *
Author Topic: Tail Light conversion help PLEASE.  (Read 1593 times)
nswiley
« on: May 12, 2014, 12:08:13 PM »
Taking trunk off my interstate, purchased a standard tail light, is there a plug and play for the wiring or do I have to cut and solder? If so where do I find one, looked bit unable to find one. THANKS AGAIN!
Highbinder
Bastian/Tazewell,VA.
« Reply #1 on: May 12, 2014, 01:46:54 PM »
If you look at the plug on the wiring coming from the trunk for the taillights for the trunk, you will see that it is a 3 prong plug  that goes to the connection under the right side cover, you can either buy another matching plug and wire it to the tail light or cut the one off the trunk and wire it to the tail light and just plug it in...only do that if you don't intend to put the trunk back on with a quick disconnect.
blackvalkyrie
California
« Reply #2 on: May 12, 2014, 06:05:08 PM »
are you selling the trunk? if so, is it black and do you know if it will fit a 97 valk standard? hows the tailight coming? Smiley
JetDriver
Columbus, OH
« Reply #3 on: May 12, 2014, 08:14:49 PM »
Don't know if this is what you are looking for, but #6 and 7 are the harness to the taillight on a std/tourer.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500CT+A/WIRE+HARNESS/parts.html
« Reply #4 on: May 12, 2014, 08:22:35 PM »
Yes they will all fit your bike if you have the mounting Brackets and hardware.
blackvalkyrie
California
« Reply #5 on: May 12, 2014, 10:23:39 PM »
Thanks..love the bumble bee!   Yes they will all fit your bike if you have the mounting Brackets and hardware.
PhredValk
Edmonton, Alberta, Canada
« Reply #6 on: May 12, 2014, 11:03:42 PM »
If you put the trunk back on, and install the CB radio under the trunk, it will interfere with the standard tail light.
Just sayin.
Fred.
VRCCDS0237
nswiley
« Reply #7 on: May 13, 2014, 03:34:36 AM »
Thanks for the info, and sorry keeping the trunk. Happy Ridding!
alph
Eau Claire, WI.
« Reply #8 on: May 13, 2014, 07:25:00 AM »
just a suggestion.  if you're running a brake light for the tail light, while you've got the whole fender assembly apart, run that same brake light wire to the turn signal area and cap it for future use.  when I S/V (super-valked) my I/S I had to run a wire for the same thing, then a year later I had to run a wire from my tail light to the rear turn signals for additional rear brake lights.....
« Reply #9 on: May 13, 2014, 08:23:36 AM »
http://forums.delphiforums.com/valkyrie/messages/?msg=11596.1
(see wiring harness part numbers)
