February 08, 2026, 05:32:33 PM
Fork resistance not equal
Topic: Fork resistance not equal (Read 719 times)
rugguy
2000 Valk I/S
Atlanta, GA
May 13, 2014, 09:20:22 AM »
I have been chasing handling issues on my 2000 I/S for a few weeks. The front end seemed mushy and I was getting a fair amount of front end "turbulence" at 70 mph and above. The only way I can describe what is happening is that the "T" created by the front wheel, the forks and the handlebars, twists and rocks left to right at 70 mph and above.
Here is what I have done:
Replaced oil and dust seals on both forks (did not remove springs).
Refilled fork oil with exactly the right amount of fluid for each fork (15w because I want firmer response)
Measured and adjusted fork lengths to be perfectly equal (they were off by 1/8")
Replaced rear shock mount bushings upper and lower
Correctly re-installed seat (middle bracket was not engaged)
Checked and adjusted proper wheel-axle-fork alignment
While replacing the fork seals and fluid I noticed that the compression resistance from each assembled fork tube was not the same. When I stood both fork tubes side-by-side vertically and pushed down on them, one side had noticeably more resistance than the other. From my limited understanding of how suspensions work, I can't imagine that they are supposed to be like that. Although, I don't understand why the internal workings of both forks are not the same either.
Before I order progressives I would appreciate any feedback anyone might have who's experienced what I am describing. I would love to think that just replacing the springs would correct the problem.
As always, all help is greatly appreciated.
P.S. If you ever have a rear handling issue and you have ruled out tire pressure, shocks and bushings, check the seat.
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
Daniel Meyer
The State of confusion.
Re: Fork resistance not equal
May 13, 2014, 09:42:06 AM »
The forks will NOT feel the same. One dampens on compression, the other dampens on expansion.
I would take a very good look at the condition of the tires, front and rear...rear particularly...for runout or unevenness...and maybe head bearing adjustment.
CUAgain,
Daniel Meyer
rugguy
2000 Valk I/S
Atlanta, GA
May 13, 2014, 09:57:46 AM »
Thanks for the info on fork resistance. I never expected that they would be different.
My Avons have less than 5k and have been maintained. Good wear path and no uneven appearance.
I will take your advice and check the head bearing.....I take from your answer that you don't think the front springs are the culprits? I only have 28k on the bike.....I may also take the front off and have re-balanced.
Thanks for the help....
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
big poppa pump
San Antonio, TX
May 13, 2014, 10:04:24 AM »
Had similar issues some time back on my '98 tourer. Rebuilt the forks with new bushings and seals, 15W fork oil, re-balanced and aligned front wheel/forks, replaced rear shock bushings and still experienced the same front end wobble. Eventually traced the problem to handlebar risers, the riser bolts were slightly loose. Tightened and torqued the riser bolts to factory specs and all has been good since then.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
wild6
(Old enough to know better)
Vernon, NJ
May 13, 2014, 11:37:47 AM »
Check the head bearing torque.
Check rear shock bushings. (+1)
Checked the torque on the tree pinch screws. (ya never know...)
“Meddle not in the affairs of the
Dragon
, for you are crunchy and taste good with ketchup.”
