January 29, 2026, 07:01:48 AM
front brake switch
Topic: front brake switch (Read 1701 times)
fast black
centerton, arkansas
front brake switch
August 02, 2009, 12:25:40 PM »
Help, my front brake switch is not working correctly. I sprayed wd 40 on connections I could get to. I can't find a replacement switch on bike bandit parts list either. I think someone was just talking about this problem on this board but I can't find it. What have you all done when this happened to you?
thanks
fast black
Re: front brake switch
August 02, 2009, 12:33:57 PM »
I would remove the switch, its just held on by single screw.....clean it and work the button over and over.....clean the whole area........
August 02, 2009, 02:48:49 PM »
The switch housing has a small vent hole in it. Spray some Tef-Lube in it and work it by hand several times. Reinstall and she'll probably be good for years.
fast black
centerton, arkansas
August 02, 2009, 04:16:14 PM »
ChrisJ and Sandy, I took your advice and
hooray
Works great and thank you both.
thanks again
fast black
August 02, 2009, 06:55:07 PM »
cool.......thats what we be here 4..................to keep Valkyries working without going to the dealership
