February 08, 2026, 05:31:42 PM *
Author Topic: new speedometer and tachometer bulbs  (Read 1160 times)
Napa Valk
Napa
« on: May 17, 2014, 03:42:55 PM »
hi everyone,
so I just got new bulbs for my tachometer and speedometer on my 2000. I got the tachometer opened just fine but when I went to take apart the speedometer it has the trip reset knob sticking out the side and I can't figure out how to get past it  how do I get it off so I can open up the speedometer case and change the bulb.
thanks Doug
« Reply #1 on: May 17, 2014, 03:48:27 PM »
Inside the reset knob is a phillips screw. Remove the knob and it'll be a breeze.
9Ball
« Reply #2 on: May 17, 2014, 04:51:17 PM »
It's a 2mm Phillips head screw (actually probably a JIS)...make sure to use a properly sized screwdriver so you don't booger up the head.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
